Turbo sump help
Turbo sump help
I had a custom Garrett built for my 88' and the OEM iol sump doesnt work properly ( I have it pinched for the moment to keep oil from blowing everywhere) Anyone know of a good sump out there for the garrett?
Are you talking about the turbo scavage pump? There is a great aftermarke scavage pump the is built from a VW oil pump. It is available from Powertech at 972 586-3210.
Be extremely careful, the oil that passes through your turbocharger has to be removed/scavenged away as quickly as it enters the turbo.. Mounting Garretts on 930 typically yield these results... Geoffrey has recommended a very good pump and a very good solution. There are others out there that will recomend that you install an orfice to restrict the oil at the inlet of the turbocharger.. This is not recommended.. When one does this, oil that is used for cooling is restricted and the life of the turbo is greatly reduced..
Got it...you guys are great...now can I pick your brains for a good intake?...consider the fact I want to keep the old CIS. I am having the guts torn out of it this summer . 964 cams ect.
