911 Turbo (930) Forum 1975-1989
The 930 rebuild.........beginning to end, the process in pictures
Old 06-26-2006, 05:09 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Lightbulb The 930 rebuild.........beginning to end, the process in pictures
Started with loss of power - down 57 hp
Then 40% leakdown:
So let's take a look inside. Heads had been shifting on the cylinders:
#3 exhaust valve had 40% leakage:
Broken rings.....fairly common:
Shop recommends new ARP rod bolts......just in case.
Also getting ARP head studs in lieu of the Dilivars from the previous rebuild.
What ho? A wobbly rod? OK, let's take it down further:
Cylinders got very hot:
Rod bearing just about gave up......LUCKY, eh?
Old 06-26-2006, 05:10 PM
TrackDays247.com
Former Vendor
Just about the worst news one can get.......soooooo close to disaster:
Old 06-26-2006, 05:11 PM
TrackDays247.com
Former Vendor
So, that's the bad news.
Time to move on.
The parts:
98m Mahles:
Long skirt Mahle pi$tons:
Ni-resist ringed the cylinders and heads to prevent leakage and shifting (not a good pic):
Imagine Auto fuel head, checked/balanced injectors:
Old 06-26-2006, 05:12 PM
TrackDays247.com
Former Vendor
Going with 7.5:1 pistons instead of 8.0:1.
After engine break - in, we will working our way slowly upwards on the dyno with:
Increasing boost (probably not exceeding .8 bar)
AFRs watched closely. Aiming for very low 12s.
Crank did not receive any damage at all other than the scratch in pic above. Needs only a polish.
Heads might be done this week.
I pick up injectors tomorrow.
Imagine Auto $500 'flowed' fuel head will be here today.
K27 Hiflow turbo needs no work and is in great shape.
Soon she'll be back doing this:
TrackDays247.com
Former Vendor
TONS of thanks to Stephen at Imagine Auto for the help.
Unbelievable knowledge.
Old 06-26-2006, 05:20 PM
im4duke
im4duke's Avatar
Are you going to try one of those map-able WUR's?
Old 06-26-2006, 05:22 PM
TrackDays247.com
Former Vendor
Good question! Maybe. If the IA fuel head takes care of the fueling issues, then no.
It also depends on how 'wavy' (uneven) the AFR chart is on the dyno - then we night need it.
Old 06-27-2006, 01:25 AM
PorschePhD
Rennlist Lifetime Member
PorschePhD's Avatar
You are welcome Criag. I am glad to help!
Old 06-27-2006, 10:59 AM
Snowboarder54
Snowboarder54's Avatar
Angry
Hmmm. This looks and sounds all to familiar. Was you first motor built by Gamroth & Weiner?? Mine lasted a wopping 8000 miles before it self destructed and I sent it to Stephen to have it done properly!!
Old 06-27-2006, 12:04 PM
TrackDays247.com
Former Vendor
Well, I'll be......
Was yours also built by them?
Old 06-27-2006, 02:22 PM
Snowboarder54
Unfortunatley mine was! How long did your's last?
Old 06-27-2006, 03:24 PM
TrackDays247.com
Former Vendor
32 hard but well maintained track hours.
I have to be fair.....
Many of the engine issues were heat and lean related.
Old 06-27-2006, 05:40 PM
Snowboarder54
Here's what mine looked like after less than 8000 miles of road driving. The car was never tracked! It worked out to about $3.00 a mile, that's not counting what I had to pay Stephen to sort it all out.
The good part now is that Stephen's build makes nearly 30 more horse power at .4 bar less boost! Go figure! It should last many miles at .7 bar.
Old 06-27-2006, 06:13 PM
TrackDays247.com
Former Vendor
1.1 bar? Who recommended that ???????
Old 06-27-2006, 09:17 PM
Snowboarder54
Good question. That's the way I received it from Portland. Humm, do you think that had anything to do with what happened to that piston in the photo?
Quick Reply: The 930 rebuild.........beginning to end, the process in pictures
