911 Turbo (930) Forum 1975-1989
need help building a new set of 930 turbo wheels
Old 02-13-2011, 05:38 PM
Twin Turbo
Twin Turbo's Avatar
Default need help building a new set of 930 turbo wheels
Just bought an 89 turbo and im looking to build some 18'' or maybe 17''. Has anyone built wheels with removing the rear spacers, will that work?
TIA
Old 02-13-2011, 06:48 PM
A930Rocket
A930Rocket's Avatar
Yes, you can build wheels with out the spacer.
I built my 18" BBS wheels using the spacer, but wish I hadn't so I could get a deeper dish look. It's easy enough to do, you just have to make sure the wheel center clears the brake caliper. If you plan on going to big reds at some point, you might have to change the center and wheel halves again to clear them.
Old 02-13-2011, 08:53 PM
Fikse Wheels
Former Vendor
Fikse Wheels's Avatar
What are you considering for wheel style? I can definitely help you with your wheel needs.
Old 02-14-2011, 09:16 PM
Noah930
Noah930's Avatar
Sure you can build wheels to eliminate the stock spacer. Just make sure you include that 21 mm (IIRC that's how thick the spacer is) in calculating the wheel offset when you select a pattern for your wheel center.
Old 02-15-2011, 01:30 AM
Twin Turbo
Twin Turbo's Avatar
I found these here on the forum and wanted to see if they would fit on my 89 930. They were on a 993 TT
17 x 8.5
et51
Yoko AVS 245/45 R17 - Tread ~50%
Rears:
17 x 11
et44
Yoko AVS 315/35 R17 - Tread ~70%
Old 02-15-2011, 08:14 AM
Dave 86 930 Fl
Dave 86 930 Fl's Avatar
TIA
I have an 1986 that I recently had custom wheels built for ... 17", 9's up front and 11's in the rear. I did not use the rear spacers, but i did retain the front spacers. I like the fitment and look of the staggered offsets (front to rear). I went with the folks at Forgeline, great people and great product.
Regards, Dave
Old 02-15-2011, 11:17 AM
JFairman
JFairman's Avatar
Yes you can build the wheels to go on without stock spacers if the wheel centers clear the caliper. Then the origonal studs will stick out the wheel holes and look like crap.
You will still need to carry least an 18 or 21mm spacer to use the spare tire or it will hit the caliper before going on all the way. Not a good surprise in a flat tire emergency.
You can cut the studs down just enough to still use the spare tire with a 21mm spacer and the studs won't stick way out and look wrong for a street car.
Old 02-15-2011, 11:23 AM
125shifter
125shifter's Avatar
For the record, the rear spacer is 28mm.
Old 02-15-2011, 11:55 AM
Fikse Wheels
Former Vendor
Both front wheels are about 1/2" inboard of where they should be for a 930. Please call or email me directly if you would like to discuss a solution to this particular set of wheels.
17 x 8.5
et51
Rears:
17 x 11
et44
Old 02-15-2011, 01:45 PM
JFairman
JFairman's Avatar
Correct and if you don't feel like storing one of those thick 28mm spacers along with the spare tire and if you have an 18 or 21mm spacer sitting around unused it takes up less room in the trunk and works with the oem spare tire/steel wheel to clear the 930 caliper... if you ever need it.
Leave your wheel studs long enough to use it if you decide to shorten them so they don't stick way out beyond the more negative offset wheel center setup you are considering.
Old 02-15-2011, 03:26 PM
Twin Turbo
Twin Turbo's Avatar
Can the studs be changed out to shorter ones instead of cutting them?
Old 02-16-2011, 12:27 AM
JFairman
JFairman's Avatar
yes, it just depends how much work you want to do.
if you're good with die grinder and cut off wheel it's alot easier to cut them and bevel the sharp edges to finish them while the wheel is off and the hubs are on the car.
then brush a little black or silver enamel on the ends so they don't rust.
Old 02-23-2011, 10:32 AM
125shifter
125shifter's Avatar
You can also use steel lug nuts and leave the studs long. It's a little NASCAR looking but works fine.
Quick Reply: need help building a new set of 930 turbo wheels
