911 Turbo (930) Forum 1975-1989
Wheels for a 930...(Fuchs 17")
Old 08-05-2013, 11:23 AM
Peter Carroll/Toronto
Peter Carroll/Toronto's Avatar
Easiest would be to jack up the car, remove a wheel, lower on a block and load the suspension, then measure by hand. There was a wheel fitment template I used in the past... Let me see... If I recall, I used this one...
http://www.fikse.com/wp-content/uplo..._worksheet.pdf
Old 08-05-2013, 11:48 AM
panzerfaust
panzerfaust's Avatar
no spacers... a redundant part that adds weight and complexity. a porsche cost cutting measure left over for standard SC fuchs for te 75-80 930 cars i reckon.
both wheel companies would have the dimesions of 930 fitaments with or without spacers. i know braids has em in hand already. im trying to get the wheels out further if possible.
Old 08-05-2013, 02:42 PM
My understanding is the spacers were left over from using 911 parts in the early homologation cars. e.g. the early 930s had front spacers and weld-on fenders. The later cars did not. I ordered my BBSs with the spacer dimension manufactured into the hub. This is stronger, has the same final offset, and keeps the stock studs. Then if I want to put another set of wheels on, I just put the spacer back. I also need to carry the spacer for the spare wheel.
Old 08-05-2013, 04:00 PM
Igooz
Trucker
Igooz's Avatar
^ PF, If you still want to "pool" wheel purchase, would you please PM your email address? (This is up to you...I am happy to run solo). (I also just sent you a PM).
I have gotten some answers and I can share some offline, and then we can share publically and help others...
Old 08-05-2013, 07:13 PM
panzerfaust
sounds good...check your pm please
Old 08-16-2013, 08:56 AM
Igooz
Trucker
Igooz's Avatar
Wheel update:
After a lot of research on various suppliers and products, cast vs. forging, desperately looking for a US manufacturer (my personal preference), style, cost and timing, I decided to go with the Fikse "Specialty" series. Frankly, I was surprised regarding the number of suppliers where you can get this style of wheels...
I can write a short essay on this topic now, so please feel free to PM me if you are thinking about wheels for your 930, etc.
My findings:
+These wheels are forged
+100% made in Canada (BC)
+3-piece with hidden bolts so that the front face of the wheel looks "stock"
+ I can get 9X17 and 11X17 and they should fit!
+They can do any offset - I will go with custom offset and eliminate the 28mm spacer (personally I don't like spacers when you can avoid them, and wheel studs are easy to change)
+ You can get them in any finish you like, and I will go with stock look: (STANDARD Finish – Black center, bright outer shell representative of the 1974-89 era Fuchs* aesthetic)
+ Delivery time is around 4-5 weeks as the wheels are custom made
+ Fikse makes these wheels for others such as Singer Porsche, etc.
+ The only thing that I need to decide today before I order are traditional wheel lip versus an optional J-Lip which makes the wheels a little bit stronger. I am leaning towards factory look as I will not be tracking this car.
I will post pix once the wheels arrive, and I start working on this car!
Old 08-16-2013, 06:11 PM
87turbo911
87turbo911's Avatar
There's a key piece of info missing from there, I think. Cost! I think they charge differently depending on the finish you choose but what's the charge for, effectively, Fuchs of the same design as I currently have now but bigger.
Old 08-16-2013, 07:47 PM
Igooz
Trucker
Igooz's Avatar
^yep! almost 4 big ones plus tires...not a small amount!
(I have been hording parts of cars for a long time, and I have a set of 16" 930 Fuchs for the car too, but I have my heart set on the 17's)
Old 08-26-2014, 02:34 PM
team illuminata
team illuminata's Avatar
FYI the 17" BRAID version is now available for pre-orders with a huge discount for the first ten sets. 930 and m491 only for now.
Old 08-26-2014, 06:16 PM
Porschekonig
Porschekonig's Avatar
Panzerfaust/Igooz - If Braid could do a run of old style Fuchs 17"s in 9" fronts and 11" rears I'd be all in! The Zuffenhaus Fuchs are very nice but the price just went up to ~ $5,600/set.
Old 08-26-2014, 07:44 PM
Before you get too excited about Fuches in 9 and 11x17, make sure you verify tire availability. A couple of years ago I sold mine and went to 18s because it was getting very hard to find good track tires... Now I run 18x9/11 and use GT3 size rubber 235/295-18. If it's for a GT3, there will always be tires...
Old 08-26-2014, 08:02 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
Did you check Lindsey racing?
Old 08-26-2014, 09:46 PM
Igooz
Trucker
Igooz's Avatar
Thank you! I bought a set of Fuchs (tribute ) from Fikse in 17" with custom backspace, forged, made in Canada, etc. I cannot say enough good things about the product, quality, and their responsiveness. I posted pix here in another thread.
Based on my research, Braid makes an excellent wheels also - I think that they are made in Germany.
Old 08-27-2014, 11:48 AM
jwl
jwl's Avatar
Lindsey Racing use to produce what they called there P3 wheels....don't know if they are doing it anymore.
Here's mine, 9x17 & 10x17
Old 08-27-2014, 04:27 PM
MUSSBERGER
uninformed gas bag
MUSSBERGER's Avatar
Fikse was always known for wonderful products but not always great at the customer service stuff. Good to hear
Quick Reply: Wheels for a 930...(Fuchs 17")
