how do you drive this beast?
I've had numerous old 911's and know what happens in a curve when you let off the gas. I am a little scared of this new (for me) 930 (and I've been spoiled by a 914-6). I won't be able to get to a DE until next spring. Is there a source I can read? A video DE? Also, while I don't want to drag race, I haven't figured out how to take off quickly from a stop. Rev the engine high? Don't want to burn out clutch.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
If you have a non standard clutch they dont slip....they clamp! My car I have to fully engage the clutch just as I give it gas. If I don't do it right it can be embarrassing.
My race car with it's 180 hp power house has the same type of clutch. My biggest fear in a race is not the first turn from green and all the associated chaos. It's getting the finger point saying it's your turn to go on the track from staging, stalling it, and holding back everyone behind me.
Trucker
I am new to the 930 and the closest thing that I had to it was a 1991 964 Turbo around 20 years ago. My 930 is all stock and freshly rebuilt, and I find it to be pretty docile. After tracking and scaring myself many times in a 6GT2 (20K miles worth) the 930 seems like a very nice and civilized car although the no boost to full boost is crazy!!!! ...love the car...
I find w/ my 930 ('77 3.0L - mostly original) when taking off in 1st I have to progressively roll on the throttle as I release clutch pedal more so than in other p-cars. In other words, the revs drop more significantly as clutch is released. I think it's mainly because the 930 transmission is obviously only 4 speeds and 1st is geared taller than most other 911s of similar era or your 914-6.
I don't track my 930 or street race, but I like a spirited drive as much as the next person. YMMV but for me revving high and then dropping clutch tends to burn clutch and doesn't actually launch that quickly. When boost hits especially in 1st though it'll climb very fast to redline... boost hits between 3-4k but then <1 second before you have to grab 2nd so be ready.
Lee
Lee
I find w/ my 930 ('77 3.0L - mostly original) when taking off in 1st I have to progressively roll on the throttle as I release clutch pedal more so than in other p-cars. In other words, the revs drop more significantly as clutch is released. I think it's mainly because the 930 transmission is obviously only 4 speeds and 1st is geared taller than most other 911s of similar era or your 914-6.Lee
uninformed gas bag
Lee
Lee
For the track, based on my so far limited experience, your biggest problem will be the brakes if they are still stock. If you drive them quite aggressively, they will fade quickly, as Porsche didn't make them big enough until the 3.3 litre cars came out. I boiled the fluid and dove into turn 7 at Toronto Motorsport Park to find no brakes. I had been lapping conservatively for about 25 minutes, then I got a bit excited when I realized I was slowly catching a Lotus Exige, so naturally I started pushing harder, and there went the brakes.
Other than that, don't trail brake, and get her straight before hammering the boost.
I don't understand why you would advise against trail braking in a 911? The whole advantage coming into a corner in a 911 is it takes a lot more to overload the front end then on most cars...trail braking has always been my friend, and with the turbo lag I can pretty much go full throttle at the apex and as the boost builds leaving the corner I'm finally at full power when the cars straight. almost like traction control, with just some wiggling when I'm really pushing.
Personally I find a 930 much less intimidating on the race track compared to the street. on the street you go from nothing to everything all the time power wise. on the track your always on the pipe/in the boost and the violent transition from no boost/boost isn't there like when pulling away from a light.
P.S. they like to be driven with cojones!
Spell Checker
As you indicate, anticipating boost and controlling it is key but not that hard in non-low speed corners. On r-compounds it can be a bit like driving a boat floating through an apex. Easy-peasy.
I only got to try the drag strip a few times when I had my 930 and I never really got it right. Always wondered how fast my car could've been with a competent (drag strip) driver.
I tried to do the rev to 4K launch with quick off the clutch while flooring it but bogged it a lot. I got a "consistent" (but slow) launch if I eased off the clutch (after slightly riding it) while gradually adding gas. So I'm guessing there would've been a sweet spot in there somewhere.
