Play in steering column
Guys,
I have noticed of late play in the steering column, there is maybe 5mm of movement when you grab the wheel and move it vertically up and down, a but less side to side. There is no play when you try to pull or push it away from you.
I am wondering if there are sheer prins and they have broken after nearly 30 years. Any clues?
Must be steering column flu going around...same thing happened to my 84 a few weeks ago...15 minute fix..
Frank
Frank
It's a very common 911 problem and it is cheap and simple to fix.
http://www.pelicanparts.com/techarti...ng_bushing.htm
