Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 912 Forum
Old 09-02-2009, 01:27 AM   #1
Gertrude76
New User
Default Transmission Fluid 912E
I was wondering if people had a suggestion for what type of transmission fluid I should be using.
Gertrude76 is offline   Reply With Quote
Old 09-02-2009, 03:03 AM   #2
hoffman912
The Hoffinator
hoffman912's Avatar
Send a message via AIM to hoffman912
swepco 201 is the most recomended gear box fluid for early porsches that I know of.
Harry Hoffman
1968 912 #3656, burgandy red -'Five Grand Fritz'
912 registry charter member #912R0195-C, Rennlist Member#: 030920-4266
Official Nine Dozen, and Leader of Youthful Indiscretion for "HWFM" Racing
Murphy is my Co-pilot.. literally pics from 2003 Cross Country Trip
pics from my 2007 Cross Country Trip
You don’t need a flat 6 to get your kicks
hoffman912 is offline   Reply With Quote
Old 09-02-2009, 11:50 AM   #3
butzip
butzip's Avatar
Hey Harry where have you been?!?!
Swepco 201 is in all my 901 and 915 trannys.
butzip is offline   Reply With Quote
Old 09-03-2009, 03:18 AM   #4
hoffman912
The Hoffinator
hoffman912's Avatar
took a break from R/L for a while, not a big fan of new management, but slowly coming back because its all about the people
how have you been man?
Harry Hoffman
Old 09-13-2009, 02:26 PM   #5
cal44
cal44's Avatar
x2 on the Swepco 201. I use it in all of my P cars.
Sports.... Opiate of Fools
cal44 is offline   Reply With Quote
Old 10-29-2009, 12:39 AM   #6
GTgears
User
GTgears's Avatar
Yep. Swepco.
GTgears is offline   Reply With Quote
Old 10-29-2009, 05:34 AM   #7
stahwille
User
Default gear oil
Southwest Petrol. (swepco) is the climbing gear oil , and 201 is bright blu in color. there is one step up with moly added. This however is more than folks need . code # 205 and not blu.. Stahwille
stahwille is offline   Reply With Quote
Old 10-29-2009, 01:00 PM   #8
GTgears
User
GTgears's Avatar
Quote:
I think you mean 203, not 205. And just for people's reference, while 203 is a great oil, it is not recommended in applications where a clutch type LSD is in place. It's too slick with the moly in it.
Old 10-30-2009, 06:09 PM   #9
butzip
butzip's Avatar
OK so any benefit in using 203 vs 201 in a 915 or 901? You don't want 'slippery' in either..... so I would say 201 is IT.
Old 11-17-2009, 11:40 PM   #10
cusigicz
New User
I accept with information:while 203 is a great oil, it is not recommended in applications where a clutch type LSD is in place. It's too slick with the moly in it.
_____________________________
Calculette pret immobilier taux interet | Calculette prets immo | Calcul credit immobilier prets
cusigicz is offline   Reply With Quote
Old 11-18-2009, 12:19 AM   #11
butzip
butzip's Avatar
Um... OK, how about open diff cars?
Old 11-18-2009, 03:00 PM   #12
GTgears
User
GTgears's Avatar
Sorry I never got back to you on this. I didn't see the reply until it was bumped.
The way that molybdenum disulfide aka moly works in a gearbox is that it provides boundary lubrication by bonding itself to the surface of the gearteeth, bearings, etc. It creates a long lasting wear surface that significantly increases restistance to the oil shearing and metal on metal contact. It basically aids in boundary lubrication both at start up and at high temps when the oil is least effective. Especially on these old gearboxes, some of which are pushing 40 years old, it will help to increase the lifespan of the gears themselves as well as the ring and pinion.
In my experience it is not too slick for Porsche's proprietary synchronizers as found in all 356 and early 911 gearboxes up until the release of the G50 box in the late 80's. However it does significantly reduce the effectiveness of an LSD by coating the friction discs, which is why we don't recommend it for that particular application.
Old 11-18-2009, 05:40 PM   #13
butzip
butzip's Avatar
So 203 is ok in there as well. Good to know as my tranny is actually 42 years old, never rebuilt or opened, pushing 450,000 miles and still getting tracked regularly. They just don't make them like they used to..... An yes she still shifts perfectly.
Old 11-19-2009, 03:43 PM   #14
GTgears
User
GTgears's Avatar
Nice. This wouldn't be the little targa they wrote a story about in Excellence a couple of years back, would it'
Tags
201, 912e, boulder, fluid, swepco, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
