912 Forum 1965-1969
My 1967 912 Build Thread
Old 05-16-2015, 03:13 PM
  #496
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Cool
Center piece ready to drill holes on cross bar
All bolted down...
Now to build the pieces that attach to the car... back in a few...
Old 05-16-2015, 06:43 PM
  #497
Wachuko
Wachuko's Avatar
Made the bases as inserts so that I can adjust height...
Car now mounted on cart!!!
I still have to do the base that bolts to the side and to the base to make it safe to transport... rear just sits on base plate...
Front is bolted
Old 05-18-2015, 03:39 PM
  #498
Wachuko
Wachuko's Avatar
I hate it when this happens... as soon as I remember where I put the clips for the inner rubber pieces...I will finish the seat! I remember collecting them all and putting them in a safe place so that I would not lose them..just can't remember where that safe place was... duh!
Old 05-20-2015, 04:52 PM
  #499
Wachuko
Wachuko's Avatar
Well... could not find the clips... so I made my own to be able to finish the driver seat
First try on covering with the laundry plastic bag... worked on the second try...
Done!
Now with the driver seat on the correct side...
Daughter came in and just had to test the seat... Daughter approved!
Old 05-20-2015, 08:02 PM
  #500
Mr Michael B
Mr Michael B's Avatar
My young handsome Son (high school) approves of the approval of your pretty daughter.
Old 05-27-2015, 05:28 PM
  #501
Wachuko
Wachuko's Avatar
Talking
Hahahaha! You keep him as far away as possible from my daughter!!!
Daniela is finishing her 11th grade... we will be a Senior next semester! They do grow fast.
Old 05-27-2015, 05:47 PM
  #502
Wachuko
Wachuko's Avatar
Originally Posted by Cdouglehman
Nice job on the cart and the seats
When you going to start that motor ?
I need to adjust the valves.
Remove carburetors to follow the adjustment steps and then install them back on the engine.
Finish the wiring for the dashboard.
Finish the exhaust (need to clean and paint the front section of the header/heater boxes) and install it.
Install the plug wires
Set ignition timing (that is going to be fun...)
Fill with oil to the correct level
I think that is it... should be able to start it right after that is done...
Added two additional bolts on each end to the cart to make it more sturdy...
Old 08-06-2015, 11:05 PM
  #503
Wachuko
Wachuko's Avatar
Not sure what happened... but I am not selling my 912 ! Not sure how anyone got that idea...
Anyway... I am just very busy at work and with the family... coming back soon to continue the work on my precious
Old 09-11-2015, 02:40 PM
  #504
2mAn
2mAn's Avatar
I love the restoration you're doing on this car! No stone left unturned on this one!!
Old 09-14-2015, 10:09 PM
  #505
Wachuko
Wachuko's Avatar
Thank you. Hope to be able to start working on it again in October...
Old 12-01-2015, 06:23 PM
  #506
Wachuko
Wachuko's Avatar
Well... not much of an update, but got a call from Alejandro that I can go this weekend and pick up the '81 he was working on (metal work and painting)...
That means that I can take the 912 to get the metal work done. He will install the rear window corner, repair the rest of the window area, install the rear shelf and weld the hinges mounts, repair the rear seat buckets, replace the passenger side sill with the new part I bought, and fix any dents in the car.
Now back to my cave...
Old 12-01-2015, 06:53 PM
  #507
John D.
John D.'s Avatar
*SIGH*....
Nicely done - I'm living vicariously through your exploits - so, please....
Keep them coming!!!
John D.
Old 12-06-2015, 11:54 AM
  #508
Wachuko
Wachuko's Avatar
Cool
Originally Posted by John D.
*SIGH*....
Keep them coming!!!
John D.
John, will do.
Originally Posted by Splash440
Jaime,
I too am glad things are settling down and you can get back to the toys. I am committed to finish mine and have it at the 2016 Rendezvous, hope you can get yours complete and join us. It would be great to see you in person.
Not at the speed Alejandro works.... But I will start planning to attend with or without the 912.
On related news. Found some cheap labor to help with removing most of the trim to take the car today to Alejandro.
Old 12-06-2015, 12:36 PM
  #509
Doug&Julie
Doug&Julie's Avatar
Is that the same son as in your avatar? Man they grow up fast. (..or you take a really long time with your projects. )
Old 12-06-2015, 03:36 PM
  #510
Wachuko
Wachuko's Avatar
Talking
Same one!! These projects have taken an eternity...
Quick Reply: My 1967 912 Build Thread
