914/914-6 Forum 1969-1976
EFI System Replacement Ideas
Old 05-30-2006, 07:48 PM
p914
p914's Avatar
Question EFI System Replacement Ideas
Anybody have ideas on replacing my djet? rebuilding the 2.0 to a slightly bigger size to get @150-170hp.
Already looked at megasquirt, CB and Autronic. Any other ideas out there?
Old 05-31-2006, 07:03 PM
Rouser
Rouser's Avatar
There's Redline Weber (bring $$$), 914 CIS (bring BSME, toolbox, & $), Emerald M3D (don't know ANYONE using it), and SDS EM-4 (ditto).
Should be enough sites to keep your head spinnin' for a while ...
Old 05-31-2006, 09:03 PM
p914
p914's Avatar
Thanks Rouser,
I'm going to spend some time looking into some of those you listed that I have not yet seen. All comments are welcome.
Old 06-20-2006, 10:02 AM
Geoff
Geoff's Avatar
In Gig Harbor, DaveHunt is running a 2270cc with Djet intake parts but with MS. Seems to be working fine! He is in the 150+hp range
Old 06-27-2006, 02:37 AM
GOSANE
GOSANE's Avatar
Dual 40 Webers
Old 06-27-2006, 06:52 PM
Rouser
Rouser's Avatar
Originally Posted by GOSANE
Dual 40 Webers
He's looking for an EFI solution, not a carb solution.
Old 06-27-2006, 09:02 PM
p914
p914's Avatar
Yeah that ^
I thought about carbs though.
Old 06-28-2006, 12:10 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
The MegaSquirt seems to be pretty popular. How about something like Electromotive?
Old 07-01-2006, 01:07 PM
Rotten Robby
Rotten Robby's Avatar
If Dave is around maybe he could explain more about his EFI system. It uses a crank fired ignition from a 90's Ford as I recall, and I think O2 sensor control as well. I watched as he went through some of the tuning with a laptop and it was impressive...
Old 07-02-2006, 04:16 PM
sc91183
sc91183's Avatar
I installed a Megasquirt ECU on my 1983-911SC with TWM throttle bodies and it's a good,cost effective setup. I wouldn't hesitate to use this on a 914 but would also consider SDS. I am thinking about the addition of a 914 to my garage and EFI would be on the "to do" list with a wideband O2. If you shop around the prices aren't too bad. The Megasquirt can be purchased in kit form and you solder it up or there are many quality builders out there that provide a turn key unit, just add software,injectors,TPS and air +engine temp sensors and you're ready to turn the key!
Old 07-25-2006, 06:24 PM
p914
p914's Avatar
Thanks for all the replies, Looks like I will probably go with the CB Ultra at the moment.
Old 07-26-2006, 10:54 AM
Geoff
Geoff's Avatar
Pretty non adjustable system, yuck.
atleast look at MS as I am going to try it out now.
Old 07-26-2006, 11:04 AM
p914
p914's Avatar
Hi Geoff,
Actually I wanted something fairly simple as I don't get in there and make a lot of adjustment. The CB has the **** to adjust between leaner and richer on the fly but I probably won't use that much.
Post when you try the MS, I've heard good things about that system too.
Old 07-27-2006, 02:17 PM
Geoff
Geoff's Avatar
That is the problem I have heard with the CB setup as you can ever get it adjusted right for the whole powerband.
They seem to go on sale from guys who have them in a few months out of frustration...... I have only seen one in person thou.
Djet is the simplest setup but it would take some work screwing with the MPS with a A/F O2 meter to adjust it right.
Old 08-01-2006, 05:56 PM
fast951
fast951's Avatar
Running a 944NA DME/Wiring Harness is fairly simple.. I'm installing it on my 914 2.1L and 2.5L Supercharged. Once I get the engine on the engine dyno, I'll post few pictures.
John
Email
www.vitesseracing.com
Quick Reply: EFI System Replacement Ideas
