fuel pump
fuel pump
where o' where is the fuel pump suppose to be located on a 71 914 1.7 L ?
mine is not working and i don't hear the buzz when the key is turned on. tomorrow i need to trace the wiring to confirm power.
i found it! someone(not the PO) put it under the fuel tank
i somehow thru testing the circuits at the connector on the circuit board manage to just start the pump working again. all i did was go from red to red/black wires and it started buzzin again.
now to get the timing and idle set properly...PO messed those up also
ahhh fun with old cars!!!
