94410514901 breather hose NLA
Old 10-26-2017, 08:04 PM
elgy
elgy's Avatar
Default 94410514901 breather hose NLA
This is the hose that goes from the fitting on the timing belt covers to the air filter housing. Mine is split and the part is not available it seems. I could put plugs on the two ends... what are other people doing?
Old 10-26-2017, 08:13 PM
V2Rocket
Rainman
V2Rocket's Avatar
thats what the factory did after a certain year - there is a tech bulletin on it out there somewhere.
its a non-essential part.
Old 10-26-2017, 08:27 PM
edalenta
edalenta's Avatar
The "official" part number for the two breather caps is 944-106-103-03.
You will also need two hose clamps (1-1/4" IIRC).
Old 10-26-2017, 08:34 PM
V2Rocket
Rainman
V2Rocket's Avatar
Cap off of some brands of spray-can brake cleaner or liquid wrench fits those ports perfectly.
Old 10-26-2017, 10:48 PM
elgy
elgy's Avatar
Thanks all...
Old 10-28-2017, 10:22 PM
Severian
Severian's Avatar
Default tech bulletin
Old 11-03-2017, 12:28 AM
elgy
elgy's Avatar
So part number 944-106-103-03 ($10.25 from Pelican X 2, one for the belt cover and one for the air filter housing. And that's about $25 Cdn). I have a better idea for about $4. Pictures and details to come.
Old 11-03-2017, 12:53 AM
Lizard944
Lizard944's Avatar
I bought a pack of those rubber walker/cane replacement tips from Walmart to cap off. Think they came in a four pack. 1 1/8" I.D. Wedge fit tight and didn't need clamps. Looks surprisingly good.
Old 11-03-2017, 09:46 PM
WolfeMacleod
WolfeMacleod's Avatar
I think mine is split open as well, I recall some hose being like that while doing the timing belt a couple months ago.
I've heard that Porsche sometimes restocks old parts that are NLA, they'll run some and put them back into stock.
They're on twitter... and are quite good at responding to messages. Maybe it's time to start asking them about NLA parts.
https://twitter.com/Porsche
Old 11-04-2017, 09:01 AM
elgy
elgy's Avatar
That's another idea... I used plastic plumbing plugs, 1" O.D. for the air filter housing (cut it down and had to file to reduce the circumference) and 3/4" O.D. for the belt cover.
I'll glue the one into the air filter housing. For the belt cover, because it is split, I'll just glue one side.
Quick Reply: 94410514901 breather hose NLA
