944 Turbo Cup Mirror Questions
Old 12-09-2017, 03:09 PM
Bmuldoon
Bmuldoon's Avatar
Default 944 Turbo Cup Mirror Questions
I finally tracked down a 944 Turbo Cup mirror for my 951. It's actually from a 924S and comes with a manual control with cables. Thinking that the setup is similar to the flag mirrors, I've been trying to remove the glass by sticking a small screw driver through the bottom holes to rotate the disc counterclockwise without any luck for a couple of hours. Is anyone familiar with how to remove the glass from these mirrors so I can disconnect the manual cables?
Since it's unlikely I'll track down a passenger side mirror, I've been thinking of just running a single driver side mirror for my 86 944T.
Lastly, can anyone confirm if this is the correct body gasket for the mirror to be mounted to the door? (See 2 on the part sheet below)
http://www.pelicanparts.com/More_Inf...8-857-579--OEM
Old 12-09-2017, 03:44 PM
PaulD_944S2
PaulD_944S2's Avatar
The mirror simply lifts off the motor driven backing plate.
If you look at #11 you will see an upper and lower hole on the left side and a single hole on the right edge.
Be careful as you pull it off, there are wires connected to the heater on the back of the mirror.
Old 03-12-2018, 01:22 PM
Todd951968
Todd951968's Avatar
Where did you find the mirror? I am looking for a Right hand side mirror for a Rothman Turbo Cup car ........the damaged mirror has the same part numbers as you show.
Old 03-12-2018, 02:43 PM
Bmuldoon
Bmuldoon's Avatar
I ended up scoring a new in box pair from another Rennlister.
However, I do have a manual driver side mirror (with cable) - I believe this originally came off of a 924 single mirror car in the UK. Certainly for sale if anyone wants it.
Alternatively if you are looking for the passenger mirror, I have a contact that has a reconditioned/used but in excellent condition passenger side mirror. PM if you want their email address.
Thanks!
Brian
Quick Reply: 944 Turbo Cup Mirror Questions
