Cooling fans
Cooling fans
When I was doing the TB change on my new to me 944 I noticed one of the cooling fans was unplugged. In asking the experts (you guys) I figured out the unplugged one doesn't turn easy. I have the old 3 blade fans, would it be easier to replace everything with a newer 6 blade unit rather then replace the one fan.
Along with that does anyone have a later fan unit to sell LOL.
I love the 6 blade over 3. much quieter, and make me less nervous when the fan turn on.
here is my conversion: https://rennlist.com/forums/924-931-...onversion.html
I have two 3 blades fans that will and up to 6 blades if you want
Seriously, I think I have a 6 blades fan lying somewhere if you are looking for one.
Rainman
the blades will swap between motors in about 30 seconds. you can use a 6-blade on a 3-blade motor and vice versa.
pry off the clip gently, pull off the blade, swap blades, reinsert clip.
Rainman
some motors ive seen (i have a lot) the end of the shaft is slightly flared out for some reason, probably to help ensure the blade doesn't come off easily.
i've had to lightly grind those to get the blades off before, yes.
