Getting out of 944 game
Getting out of the 944 game. Gotta say it’s been fun.
’86 944 N/A, needs a new home,needs some work……. head gasket, tires, battery, some body work.
It does have a lot of add-ons.
All black interior. (pics show it before it was all changed to black)
Fiberworks front and rear bumpers molded into the body, (bumper shocks removed), sidelights filled in.
GT Racing fixed headlight kit (not installed). Modified driving lights w/ 100w bulbs. (pics show it before lights were re-installed)
Ground Control camber plates, ride height adjustable struts w/Koni sport (adjustable damping) shocks on
front and rear.
Eibach 250 lb front lowering springs. (rear lowered w/ eccentrics) lowered 1” all around.
Weltmiester Stage II front and rear sway bars.
Rennbay (Wilwood) front big brakes , Wilwood front pads, Hawk rear pads.
Zimmerman cross drilled rotors all around.
GT Racing fixed headlight kit. (not installed)
Rennbay headlight relay kit.
Braided stainless steel fuel lines.
Braided stainless steel brake lines.
Staggered (7”- 8”) early offset (23) Turbo (16”) phone dials. No spare. (I ran 255/50 on the rear,
245/50 on the front).
Weltmiester ? performance chip.
Poly control arm bushings, Rennbay balljoint rebuild done.
New water pump, thermostat, timing belt and rollers.
Fidenza light weight flywheel.
New clutch master cylinder.
Adjustable high pressure fuel regulator.
MSD 6 ignition.
MSDS headers, 3” pipe to California compliant cat converter and Walker muffler.
Wide band O2 sensor and guage.
AC delete.
Overbored throttle body, cone filter intake.
Racing Dynamics strut brace.
Performance Products short shifter kit w/shortened shift lever.
Cerrullo GT seats (vinyl)
G-Force 5 point harness on drivers seat, (stock seat belts are still installed on both seats.
Halon fire extinguisher.
New sunroof gear housings (not installed).
Light reflectors in gauges have been replaced , all gauges and clock work, w/extra gauge cluster.
Odometer gear has been replaced and shimmed. Extra gauge pod included
All glass is good, no cracks, windshield has tinted upper, w/ in glass radio antenna.
All electric windows functional.
Pioneer PEH-4300 AM/FM/CD /w removable face plate. All speakers have been replaced.
Dash recovering kit (vinyl, not installed).
Aftermarket electric door locks, w/remotes.
Pelican Parts flywheel lock.
Any interest, contact me, we can talk more.
front and rear.
MSD 6 ignition.
AC delete.
KEVIN ANDERSON (06-25-2019)
