1988 NA no start
Old 07-07-2019, 05:42 PM
Falcondrivr
Falcondrivr's Avatar
Default 1988 NA no start
Did a search, no joy.
My 88 NA will start and run perfectly, until it sits out in rain. Then it will not start. I’ve checked and there is spark on all cylinders. After it cranks for a few seconds, when I stop cranking, it tries to chug once or twice. I put it in the garage for a few days and the problem goes away. It will then start and fun perfectly unless left out again.
Any ideas?
I did the air flow petentiometer mod, and checked the connections for the reference sensors, tach bounces while cranking.
Old 07-07-2019, 05:56 PM
Charlie
Charlie's Avatar
Have you checked the battery box to see if water is leaking into the cabin?
Old 07-07-2019, 06:52 PM
Falcondrivr
I unplugged and reattached the ecu harness and everything is dry down there.
Old 07-07-2019, 11:00 PM
75ohm
Resistance is Futile
75ohm's Avatar
Does it do this when you wash the car too?
Old 07-08-2019, 12:44 AM
MAGK944
MAGK944's Avatar
If one of the sunroof drain pipes is detached it will cause water in the foot wells.
Quick Reply: 1988 NA no start
