Odometer Problem Solved
Old 08-31-2009, 10:53 AM
poor-sh-nut
poor-sh-nut's Avatar
Talking Odometer Problem Solved
Took the gauge cluster out again Saturday for another look. All gears looked good. Turned the worm gear and everything worked fine. Tried turning the one gear that always is suspect. It was like a piece of rubber. I bent it sideways and it crumpled. What was happening is when the gears meshed and turned, the teeth on the bad gear just bent and rode over the other gears. I replaced the bad gear with the new one I had purchased. It all works as it should now. Thanks for all the help guys/gals. One more thing fixed on the car. Now to work on the short in the moon roof circuit.
Old 08-31-2009, 11:04 AM
bearone
bearone's Avatar
was the outside gear the bad one?
87951
95sl320 dd
Old 08-31-2009, 02:26 PM
Van
Van's Avatar
Where is a good source to get replacement gears? My odometer stopped working Friday on the way to the track (re-set the trip meter when I got gas). It did last 126,000 miles, though.
Old 08-31-2009, 02:52 PM
bearone
bearone's Avatar
i got them from rennbay.
87951
95sl320 dd
Old 08-31-2009, 03:35 PM
CurtP
CurtP's Avatar
Rennbay.
Quick Reply: Odometer Problem Solved
