Resealing 951 intake questions
Howdy
Wondering if someone could answer a few question before I start ordering parts...
There seems to be a bit of conflicting information about proper 951 fuel injector o-ring size. I dont know which kit is actually correct and dont want to tear my engine apart only to have the wrong ones. Can anyone link me to the proper one?
Also, once my intake is off...you seem to gain access to a lot things I'd like to refresh. Can anyone suggest what "while I'm in there" replacements I should do? Hoses and such...
Thanks...
Thanks...
According to PET the kit you want it part# 94411090100
As for wyit well start at page 54 and see what needs replacing but from personal experience look at hoses, vacuum lines, rubber mounts (on ICV), seals (on AOS), and it’s a good time to delete the venturi and emissions system if permitted in your state.
If you want to go deeper then send your injectors off to get flow-tested and balanced and they will come back with the correct new seals and look like new, Ive used WitchHunter in the past. Lastly, it’s a great time to do the fuel lines.
