Remove plunger from lifter
Old 05-30-2020, 08:25 PM
jjbunn
jjbunn's Avatar
Question Remove plunger from lifter
Has anyone had any success removing the plunger from a lifter? I've seen methods advised such as banging the lifter on a wood block, or pulling the piston out with needle nosed lock pliers, but neither work for me. It looks like the plunger surround is peened over at four or more points, which may explain the difficulty?
Old 05-31-2020, 08:47 AM
GPA951s
GPA951s's Avatar
NON- Removeable, It is crimped together... If that center part of the lifter comes out, the oil pressure behind it will over-stroke the valve and smash it into the piston.. Ask me how I know.. LOL
Old 06-29-2020, 11:57 AM
willrobinson
willrobinson's Avatar
They can be removed. If i remeber correctly you will have to depress the plunger and use a dremmel or similar to flatten the deformation from the 4 peened points and then bang it on some wood as reccommended. Can I ask why you want to do this?
Quick Reply: Remove plunger from lifter
