'81 931
I wanted this one pretty badly because of the paint code - my max bid was $15k.
It's funny, I don't particularly care for the ROW bumpers on 944s, but I LOVE them on the 924s. Weird, I know. Seriously stunning car - do you have any more pics by chance? How about interior?
Have you had a chance to run with, or have you owned a 3.0 SC? I honestly think the cars in euro trim could give a US emissions-choked 3.0 a run for their money.
We moved back to IN from NM in 2013/4. Initially lived up near Alexandria but have since moved down south closer to Cincy, but on the Indiana side (Brookville area). It's nice - lots of good driving roads, with a bit less traffic than the other parts of the state with similar topography (Bloomington...). The Whitewater Valley area is a lot of fun - great parks, water sports, hiking, etc.
Are you guys in Evansville or Indy? We need to get hold of Jerad and do a meet up!
Holy smokes, that color is stunning. Granite Green Metallic? Has your car had a respray?
Here a pic in the sun
Oh forgot, interior pix also. I love these funky 70:s and early 80:s interiors from Porsche 👌
This old article from Petrolicious explains it better than I can; it's basically a nonabrasive cleaning process. It takes around 6 hours, and gets the underside of the car (and wells, engine bay, etc) as clean as possible without disassembly and without blowing water/steam into nooks and crannies where it doesn't belong.
Karl_W944 (10-04-2020)
Wow, that method did an amazing job!!! The results are incredible!!! Honestly well worth the time put in on a car as nice as this one!
Micah (10-04-2020)
This past week I had a new dashboard from Werk924 installed in the car.
I had previously purchased the dash in Dec of 2020 and was finally able to squeeze my schedule around other car repairs/events in order to get the 931 to my mechanic (Terry at Euromotorworks in Indy) for the install.
I had the dash shipped directly to my mechanic back when I first purchased it. There were customs issues with DHL, but thankfully it wound up being delivered in one piece.
Bottomline up front: The dash is a quality piece, and is, in my opinion, your best option currently in the market. However, it is critical that you understand a couple things - namely, it is not cheap and it is not perfect.
With shipping, customs, professional installation and tax, I was on the north side of $3,800 from cradle to grave with this project. Now, I had every bulb in the dash replaced "while you are in there" and did ZERO work myself. I dropped the car off, screwed around driving other Porsches all week, and then picked it up. Keep in mind, the dash, as shipped with customs, etc was nearly $2k on its own.
Regarding perfection, there is some consternation out there that the dashboard is not a perfect fit. For the price, there is an argument to be made that it should be absolutely perfect, but depending upon individual budgets, this is going to be a very subjective argument.
Colorwise, the dash is 95%. The OEM brown had an almost imperceptible bit of black "mottling" to it, but your eye can't really catch the difference without doing a lot of back and forth work in real time. FWIW, color was my primary concern, and it was a non-event. The texture is a virtual exact match.
Fitament is 90%. The dash is not, in my opinion, too short. In fact, my mechanic stressed that the thickness of the material of the dash actually makes it slightly bulky. In the arguments I have seen, the perception of being too short manifests itself in the gap between the dash and the door panel (particularly on the passenger side) when closed. In reality, the Werk dash has a slighly steeper angle at the edge than OEM. As a result, this appears to pull the the dash away from the door panel further than the OEM unit. This is particularly noticeable at the lower right corner of the dash where the air vent is located. In this spot, the dash not only contends with door panel edge, but also has to angle towards the floor. Pictures are attached. My glovebox door has slight warpage from 40 years of existence. Don't know if I'll bother replacing it or not. Probably not. My mechanic noted that fitting the vents was very tight, but workable.
A final note about fitament. Only an expert would notice the aforementioned door panel gap "issue." It is only apparent to those of us who really know these cars... and even then upon direct comparison to OEM examples. Not once, in driving it nearly 300 miles this weekend, did I glance at the dash/door gap and get frustrated. YMMV.
So... is it worth it? That ultimately depends on the individual. My 931 is a solid #2 car with lower miles. I maintain it without regard to cost, and I would put it against any early car with the same miles in the country. With that having all been said... I am perfectly happy with the fit.
If the money is unacceptable to you... do as owners have been doing for 30 years and throw a cap on there.
Hopefully someday Porsche Classic will dust off the old molds and get to work... but until that happens, Werk924 is the only game in town. I have recently heard that they unfortunately lost an associate due to Covid, so I certainly hope they are able to move on from that tragedy. They are obviously a quality company making a quality product. I am happy with the outcome, and wish them all the best.
Passenger door, shut:
Passenger door, ajar:
Driver door, shut, detailed view:
Passenger door, shut, detailed view:
Passenger door, pillar view:
Driver's door, pillar view:
jeyjey (08-15-2021)
I have a dash that was leather covered by classic 9 leather..
It is very nice other than still a bit of wavyness by the defrost vents..
not my pics, old pics from seller..
ugh.. maybe I should go get my own pics..
Even if I had a lift, I know I would maybe finish a couple wheel wells in the time it takes them to do an entire car.
I have had 4 Porsches done, and been thrilled each time. Coincidentally, I just picked up my 914 from them today after they did a demo cleaning of it for the local PCA guys this weekend.
