Early fuel tank options?
I need to replace the tank in an 83 I’m restoring. The strainer is broken and completely frozen. Any attempts to remove it have further damaged the tank and there are just too many holes and tears to repair now.
Are there any options for replacement besides finding another early tank and resealing it?
H.F.B. (04-14-2021)
I was thinking of installing a plastic fuel tank in my early race car as my 10 gallon fuel cell is annoying to me
due to it's small size ... almost ran out of fuel a few times during practice and qualifying.
Anyhow , i bought a used plastic fuel tank and after i realized all the work and other parts that were involved , i gave up.
From what i understand , there's cutting of the transmission mount involved and i didn't think it would be safe for a race car.
I saw some posts on Pelican from people who attempted it , but it wasn't for me !
Cheers
Phil
Cheers
Phil
Rasta Monster has a write up of it on 924board.org. It didn't seem all that hard.
http://www.924board.org/viewtopic.ph...ight=fuel+tank
I feel your pain. I have removed and repaired my early tank. They are steel tanks, and can be soldered with a hot air gun. (1000 degrees F or better). ans acid core solder. You can call Retro automotive, in Claremont NH a warehouse of used parts. He has several and is easy to deal with. Straight shooters. I have been there quite a few times..Ask for Roger. You could also send an e-mail to Plyhammer's parts. He might have one as well. You can ask Roger to pressure test the tank for you, and /or send it out to a local (to him) radiator shop for a more professional checkout, prior to shipment. Just a suggestion or two.. You don't say what part of the country you are in. Hope this helps.
Gas tank
I had to address this issue with my '84. I was lucky enough to get a good used one, but to be honest, I would have been OK if it needed some welding to get it right, because then I would know it was solid. I have this one pressure tested at a local radiator shop and it came back good, but I also sprayed layers of truck bed liner on the known area that cracks, just to be sure that it would be good for the future. Got it in, and that was a year ago, and it's fine still.
If it wasn't for the fact that the transmission has to come out, it would have been done in an afternoon. Took me and my ham-fisted abilities two days to do on a lift, but I did take my time and did not have any help.
John
John
Did you try Retro automotive in Claremont, NH? Last time I was over there they had several tanks, mostly plastic, but some metal ones too.. Ask for Roger. Don't know where in CT you are, but they can ship too. They're about an hour North from me, in Fitzwilliam, NH. Close to the corner of VT and NH and MA. I'm about 1/12 hours out of Bradley Airport in Windsor Locks, near Hartford and Springfield. Right on 91. PM me and we can get together for coffee, a hello and a trip up to Retro. Pfarah7 and I both frequent the place. Great folks.
That sounds like a good idea (road trip)! I'm about 20m from Hartford down Rt 2 towards New London. I'll PM you if we can get this finalized.
Tiger03447 (05-28-2021)
Sounds good..Bring your old tank with you for comparison when we go up to Claremont..(saves shipping costs and allows hands-on). BTW I reread your earlier post and the entire thread (so far). Have you tried using a dremel to cut the inside of the strainer ring? If you do this, it may relieve enough of the rust to be able to turn the strainer out. I had to do this on the fill plug of my gearbox. If you could cut a chunk out of the ring, it would be better..Relieves the stress of the rust in the threads, plus liberal amounts of PB blaster or brake leaner to flush out rust and remaining pieces of the ring. that way, if it won't turn, you might be able to get it to turn with a punch and small hammer. Or just blast out a section with the punch and fold it inward..If somehow you bugger the threads of the tank, you could probably use Gasgacinch (Edelbrock product for fuel leaks) to seal up the threads. HTH some.
Understood....Just take some photos, and measurements. Mine is in the car, so that option is out and I don't have another. When you take the photos, put the measuring tape in the picture, so you can correlate from your tank to his tank a bit better. I'll send a PM if you still want to come up and take a look-see.
