Baked your hubs at 250ºF for bearing change?
I've ordered the VW front bearings and seals to replace on the 83 and am getting ready to do the R/R as described in the Clark's Garage procedure.
Curious if anyone has actually done the oven baking of the hubs and kept their seals in the freezer overnight to get them in the hub.
TIA
TIA
I have done the heating/cooling thing and it does work. Only I didn't use the freezer, it was 15F outside when I did the work, just left them outside on the porch. It does work, but you have to move along as the temperatures stabilize, any advantage is lost.
Just did it a few weeks back. I initially tried without heating and let me tell you, you don't want to try without heating. The races came out like butter with one whack while before I didn't seem to have the heart to whack it so hard.
Regards.
Regards.
Dan,
You heat the hubs up, to remove the old races, and install the new. The expansion caused by the heat increases the difference in diameters between the race, and the hub that encompasses it. This allows you to more easily remove the race from the hub. By chilling the new race, you further increase the difference between the two parts, thus making the installation of the new race that much easier.
-J
-J
Originally posted by Jon Moeller
Dan,
-J
Dan,
-J
Thanks guys. Glad it works and I'll be giving it a try next week...
Jeeper31, you don't need to resort to this for the rear trailing arms on the early cars. I have heard of a similar trick for the post 85.5 rear wheel bearings, though.
If you do a search, you'll find a recent thread about them that I posted the part numbers on. Here they are again:
Front Wheel Inner Bearing: 211.405.625
Front Wheel Outer Bearing: 211.405.645.D
Front Wheel Seal: 477.405.641
It's great buying VW parts for these cars. So cheap compared to the 944-specific. Hope this helps.
Yes, i will attest to the "do not try this without heating the hubs" I did it this way with a bearing race set, and it took about a half hour of pounding, and was a pain in the ***. I figured if i threw them in the oven, the girlfreind would throw me in the oven, so that is why i didnt do that. Acetylene torch would be handy, but don't have one down here....why couldn't someone have told me to use the grill idea before....arrggg that would have been perfect...lol
