remove HVAV on 968
remove HVAV on 968
I originally raced PCA E class, so took limited stuff off car before I had cage put in. Now am changing to SP3 so need to lose weight.
Have removed heater/AC blower motor and heater core. Part of passenger side dash lower glove box gone. Have released bolts where heater/AC lines go thru firewall. Have removed ducting to HVAC box on passenger side. Have removed the bolt holding the HVAC unit to the upper dash on passenger side and the L shaped bracket in the engine compartment holding the HVAC unit,
Now I need to remove the upper nut on the bolt on the driver side,
Can I do this without taking the gauge cluster out? If I take the gauge cluster out will I be able to reach this nut/bolt?
Anything else I will need to remove or disconnect?
thanks
Dave
on R passenger side I removed nut from upper bolt on frame. How do I get to the nut/bolt on the L drivers side?
thanks
Dave
Presumably you mean this one:
If so the removing the cluster trim piece should be enough (although the part of the dash the instrument cluster and trim piece screw into might be in the way).
dave968M3 (05-16-2021)
