No Start Problem
#242
Edit: I misunderstood your statement. It is intermittent in the sense that sometimes it will start and idle very rough around 200 and then die. And sometimes it will start and immediately die.
#243
The temp sensor is affecting the fuel output not spark. The problem right now is that there isn't enough fuel output to keep the engine running. I think we can rule out everything that doesn't pertain to fuel delivery from the injectors.
#245
Unless it is an intermittent problem involving something else but unlikely as it always run with starting fluid.
#247
This is literally an impossibility if the fuel injectors are spraying into the cylinders in pulses and doesn't fire while starting fluid makes it run as you have checked for large vacuum leaks. Provided that what it is spraying is flammable.
#248
#249
Yes, the AFM is connected, but from what I understand, it is bypassed on cold start till the air valve closes. When I apply gas it does, so we deduced that it was leaning out. The cylinders are not getting enough fuel to keep running but they are getting enough to fire up.
#250
So what happens when you apply throttle? Does it run right, fire on all 4, and responsive?
#251
When you push the accelerator with starting fluid (longer bursts due to the need for more fuel), does it rev up?
When it is running on starting fluid, you can check to see if the injector pulse increase in frequency as the rev goes.
Also, if you pull the injector rail up with the injectors squirting into cups while the car is running on starting fluid, you may be able to see physically what is going on with the fuel flow out of the injectors in real time. Be very careful as if you spill the fuel onto arcing plug wires, it can catch on fire so have a fire extinguisher ready with someone helping you.
#255
I haven't increased the revs while spraying fluid.
