No Start Problem
#271
PET calls for the same all years for US. I would double check the markings on each before swapping. If Pat drives his 944 over and his works in your car, make sure yours does not work in his car to confirm. In fact, maybe do this first instead of risking his ECU in your car.
#274
If the DME works with starting fluid, it works for gas.
I wouldn't be looking at the DME right now.
You have to see if larger amount of starting fluid and more throttle will make the motor rev up higher.
If this is the case, you are not getting enough fuel.
The steps are systematic. Right now you are playing the guessing game and doing trial and error with the DME.
It doesn't rule out the DME but the starting fluid test takes a few minutes will narrow down the problem significantly.
#275
#276
#280
It sounds like you have a line on a spare ECU.
Altough I cannot personally volunteer, since I don't have a 944 at the moment, there is a world where you put your ECU in a flat rate box and send it to one of the folks participating in this thread. They can plug your ECU into their car and see what happens. As far as I know, there is zero risk that a bad ECU can do damage, especially if it doesn't allow the car to even start. I'm sure if you ask, someone will support you in this effort.
#281
#282
You know it runs. How does it run under throttle with increased amount of starting fluid? Does it rev up like normal or not?
While it is being revved up with starting fluid, do you know what the injectors are doing in terms with injection pulse frequency via the noid light as do they all increase in frequency with increased RPM as they should?
Also, do the injectors actually open and close spraying into a cup with higher frequency in correspondence to the injector pulse? Also, do they spray corresponding amount of fuel into the cups as the RPM increases with more throttle/starting fluid?
#283
#284
#285
