No Start Problem
Old 04-26-2022, 01:24 PM
  #106
T&T Racing
T&T Racing's Avatar
Originally Posted by Legoland951
I have seen check valves stuck at the pump, bad pump, bad DME, shorted wires in the injector harness, corrosion in the connector of the DME, stuck injectors, and more even if it runs on starting fluid. The noid light will simply narrow down or eliminate certain possibilities. If it pulses, it eliminates the DME, shorted harness, and anything electronic but not electrical.
Acantor. Legoland951 states it correctly that the noid light narrows down the possibilities, anything electronic but not electrical. The noid light is going to verify some of the tests you already ran and verify that the DME is switching the 10..6v pin on the fuel injector connector to ground when cranking the engine, thus making the circuit close across the +12v pin and the other floating pin in the connector. U believe I purchased my noid light from Amazon
Old 04-26-2022, 01:32 PM
  #107
Acantor
Acantor's Avatar
Ok I will get that ordered today. Should be able to use it mid to end of week
Old 04-26-2022, 02:07 PM
  #108
GPA951s
GPA951s's Avatar
they are nothing special… i just use a 12v license plate bulb i soldered wires and connector to..any 12v bulb will work
Old 04-26-2022, 02:14 PM
  #109
Legoland951
Legoland951's Avatar
Never tried that myself though it sounds like a good idea. A "Bosch" patterned noid light is fairly cheap though from what I remembered. But then again I bought these things back when the fuel pressure regulators were around $50 new...
Old 04-26-2022, 07:05 PM
  #110
Acantor
Acantor's Avatar
A little update. I did another smoke test, and there was very very small amounts of smoke. It was a considerable improvement from the last time I tested. The smoke was not constant, it was in short intervals and would disappear for 30sec before reappearing again. I feel like I have ruled out a vacuum leak as part of the problem.
I have ordered the noid light and It will be here tomorrow, so I will update you then
Thanks for all your help
Austin
T&T Racing (04-26-2022)
Old 04-26-2022, 09:56 PM
  #111
Legoland951
Austin
I do not understand. What is the smoke test? It disappeared while the car was running (for 30 seconds while you sprayed starting fluid to keep the car running continuously for more than 30 seconds?
I think the things that are ruled out is timing, compression, and spark. It is a fuel problem and still possibly a vacuum problem. The starting fluid has the "correct mixture" to replace vaporized fuel that should have been injected into the cylinder under certain timing and duration and pressure.
Now we are eliminating the electronics of the fuel injection as the problem.
After that,check the fuel is getting to the fuel rail and under the proper pressure. This will eliminate the electrical portion and some of the mechanical (check valve) as the problem.
If the problem persists, then your injectors may mechanically be stuck or fuel pressure regulator or damper maybe be broken.
Once the car is sorted enough to run on it's own, then it is time to hunt down potential vacuum problems if it doesn't run correctly.
Old 04-26-2022, 10:34 PM
  #112
Acantor
Acantor's Avatar
I have a smoke machine that I used to check for vacuum leaks (put it in a vacuum line and it makes smoke so you can see where the leak is). As for pressure in the rail, it is steady at 36psi(I have a gage from lindsey racing) and I replaced the regulator and damper.
This thread is pretty long and we discussed the regulator and stuff a while back that's probably why you didn't see it.
Old 04-26-2022, 10:47 PM
  #113
Legoland951
My first post in this thread I stated I will not read all of the posts above as I have my own routine for diagnosing no start conditions.
Sounds like you will not have injector pulse or your injectors are stuck.
Old 04-27-2022, 12:25 AM
  #114
Acantor
Acantor's Avatar
gotcha, we will hopefully know tomorrow when I get the noid light👌
Old 04-27-2022, 08:23 AM
  #115
T&T Racing
T&T Racing's Avatar
Acantor posted that the fuel injectors were cleaned and tested, only second cause is to be tested
Old 04-27-2022, 11:44 AM
  #116
Legoland951
If this is the case, check for shorts in the injector wiring harness and/or look for a loaner DME to swap out.
Old 04-27-2022, 05:39 PM
  #117
T&T Racing
T&T Racing's Avatar
Can run the fuel injector system test by removing the fuel rail and inserting each injector into a separate container of equal volume. Crank the engine for several seconds. Observe the volume of fuel in each container. The rest of the test is posted.
Old 04-27-2022, 06:40 PM
  #118
Acantor
Acantor's Avatar
Ok i just checked injector pulse with the noid light, and I do in fact have pulse. Does that throw it up to an injector issue, because if so I will get in contact with Whitchunter and let them know. The injectors were fine before I sent them there.
If you want me to, I can do the container injector test that T&T suggested If you nee me to.
Old 04-27-2022, 07:17 PM
  #119
jeyjey
jeyjey's Avatar
I would still do the container test.
Old 04-27-2022, 07:19 PM
  #120
Legoland951
Do you have pulse in all 4 injectors? That sounds very odd. Normally all 4 injectors do not fail. Something doesn't sound right here.
Yes you will need to physically verify these injectors are indeed not opening even with injector pulse and proper fuel pressure.
Quick Reply: No Start Problem
