Sway Bar Color
I did mine in an old Ford blue (post #10): https://rennlist.com/forums/924-931-...n-trouble.html
Cheers
Cheers
I would skip paint and get them powder coated. Color is obviously your choice, I'm always a fan of original. Had mine powder coated in gloss black, will last forever.
If you get them powdercoated, which I think is the way to go, spend some time with the shop that does the work (or if you do it yourself) and really figure out where the bushings are. Since there's not a good bolt hole in the sway bar, you'll want to get the piece supported by wires right where the bushings are. That way you can still get a good ground for applying the powder, and anything that isn't fully powdercoated gets protected by the bushing. As a bonus, that non-coated bit gets hidden.
Cheers
Cheers
Just following up. I agree the powder coat would be the way to go but for now I found a decent looking Blue on the shelf in the shop. the car is a silver blue if you will so some similarity. Ill put up a pic when done later today. We have nice weather for painting.
