944 spec racer & road car in one - Project thread
#136
I really like the concept of this car... track & road with all the necessary funtionality for both.
That is a great idea with the battery interchange concept. You get the marginal benefit on the track, but then can easily switch back to a full size unit which certainly would feel "safer" when you are heading on a long road trip!
Progress is great!
Progress is great!
MrQuiet (04-09-2024)
#138
Progress! The dashboard is in.
The shift light is Shift-P2 from Ecliptech. Polished the front glass and generally cleaned and refurbished the instrument cluster. Made a beauty cover to replace the right side plastic dasboard profile, that had various empty slots. Moved the hazard switch over to the left side of the HVAC controls, to where the heated rear window switch was located. Made new gaskets for the ventilation (From felt fabric), to ensure all air is directed to the windshield when needed. I am sitting very low in the car, so the steering column is lowered 10-15mm, by spacing it down on its mounts. Hence the gap between the instrument cluster and steering column cover.
I ran into an issue I have not understood 100%. I have enough wiring in the car to turn on the ignition. And the instruments, fans and some instrument lights are working. I still do not have anything in the engine bay, and the DME computer is not in place yet. But… When I turn the ignition off, the instrument cluster and the little HVAC interior fan stays on. And there is a bit of voltage at the first part of the DME relay. The voltage at the DME relay is certainly dropping, as the diagnosis LED light on my Ftech9 solid state relay is getting a bit dimmer. So something is happening to the voltage. I have isolated this to the Terminal 15 relay staying activated (closed), when I turn off the ignition. I measure 3-4V on the constant 12V at the coil, being fed by through the Terminal 15 relay. The ignition shuts fully off, both if I remove the Instrument light fuse (# 38) -or- remove the right side connector from the instrument cluster. It might be related to my hardwiring the alarm module bypass, where one of the two alarm jumper leads feed the alternator 12V field initiation, from the instrument light fuse (fuse 38). However; My hunch is that this is related to the diode between ground and 12V, on the charge light warning bulb circuit, in the instrument cluster. This circuit is hooked to the car through the right side cluster connector. But… Rather than continue the search, I have opted to push this until I have the engine, with alternator, coil and DME computer in the car.
#139
Assembly of the drivetrain and shifter linkage underway. Spent some time switching back and forth between various components, testing to identify what combination of shift linkage provides the best precision, to minimize play at the shift ****.
Selected the less corroded version of the parts I had available. Replaced the original plastic bushing with a repro-unit from Partworks (large white unit, with two large holes at 90 deg). The Partworks kit included shims, to balance play and stiction. Also, I have three different types of cross bar available (The link bar with two ball joints, going across the top of the transaxle). The original 39 year old unit, the model from Only 944 and unit that came with a "precision" kit, that was bought used. Of unknown origin. To top it off I have the Only 944 shift **** arm, with the needle roller thrust bearings.
What I found was that the longitudinal play at the shifter ****, as result of play in the linkage, was more or less non present. However there is longitudinal play as result of movement inside the transaxle. I assume this is inherent in gearbox design. Not something I can influence.
The needle thrust bearings of the Only 944 shifter arm minimized play at the forward end of the system. But there were significant differences between the three cross bars. I measured the following transversal play at the shift ****:
- Original 39yr old link = 10-11mm
- Only 944 link = 6-7mm
- "Precision" link = 1-2mm
