Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 09-25-2009, 06:29 PM   #16
garyabc
User
Kevin,
When I saw your post I went right out to the driveway, put the car up on jack stands and tightened the "pinch bolts" that clamp the torque tube into the transax'. The nuts look like they could be brass (?!) so I drew them up 1/2 a turn. Test drove the car but it didn't help.
Driving with my head out the window, it sounds like the noise is further forward. Passenger agrees. It seems to be under the car in line with the center of the door.
So I raised the car again to see if there was another clamp further forward, but of course there is not. This time I tightened everything I could find under there, but still no change.
Magk,
My noise has an underlying clicking sound, like turning a ratchet quickly. No hissing though. I may try to make a quick recording of the sound and post it.
garyabc is offline   Reply With Quote
Old 09-25-2009, 10:39 PM   #17
garyabc
User
Arrow
Here's a 30 second clip of my noise:
Old 09-25-2009, 11:13 PM   #18
944Ross
944Ross's Avatar
Try it with light pressure on the clutch pedal
'86 944/2 ..........'52 Ford F-1.......... '91 H-D FXRS-C
'94 Mustang GT.......... '69 Triumph Bonneville
944Ross is online now   Reply With Quote
Old 09-26-2009, 10:16 AM   #19
thirdgenbird
User
ive got a similar noise as well, i'm don to thinking mine is down to the cat or torque tube.
thirdgenbird is offline   Reply With Quote
Old 09-26-2009, 10:35 AM   #20
garyabc
User
Hi Ross,
Drove around with varying amounts of clutch pressure. There doesn't seem to be any change in the noise. There's no noise when the clutch is disengaged. It's difficult to get the clutch to slip and still get the engine RPM up on deceleration, but with light clutch pressure there's no change in the sound.
The engine speed that this occurs seems to have moved from 3200 RPM to 3500 when I tightened the torque tube clamp. I'm going to see if there's a torque spec for those, or any alignment requirement.
Old 09-26-2009, 10:41 AM   #21
garyabc
User
Thirdgen,
If I get inspired, I may put the straight pipe back in and see what the dif is.
Old 09-26-2009, 01:12 PM   #22
RockStar951
RockStar951's Avatar
I have the exact same sound on my 951. I currently have a straight pipe / no cat. So you might want to rule that out. I was under my car today to try to diagnose this problem to no avail.
RockStar951 is offline   Reply With Quote
Old 09-26-2009, 03:29 PM   #23
whalebird
whalebird's Avatar
Dudes, get a mechanics stethiscope. Sears, Harbour Freight all have good ones. You have to have one anyway if you are going to own a Porsche. It may be helpful to jack up the car and lightly tap on everything, especialy exhaust, with a rubber mallet. You will find the culprit with these tools.
whalebird is offline   Reply With Quote
Old 09-30-2009, 11:18 PM   #24
garyabc
User
OK whalebird,
Got the stethoscope.
Do you know anyone that I can duct tape under the car to listen for the noise while I drive?
If I over inflate the tires I think I can get close to 6 inches under there.
Old 09-30-2009, 11:28 PM   #25
thirdgenbird
User
Quote:
Originally Posted by garyabc View Post
OK whalebird,
yeah, my thoughts exactly... pretty hard to listen to an "in gear clutch out" noise under a car. maybe 4 treadmills and a creeper? i'll watch...
Old 09-30-2009, 11:42 PM   #26
garyabc
User
Plan to do the timing and balance belts tomorrow (my first time). If that goes well I'll have to decide whether to search for the mystery noise again, or just wait to see if it gets worse. Was hoping someone would recognize it.
Old 10-05-2009, 10:36 PM   #27
Photodan
Photodan's Avatar
I don't want to freak you out but I had a similar sound under the exact same circumstances, very RPM specific. Ended up being a pinion bearing starting to go, even though the sound seemed further up and nothing like what I thought a bad bearing would sound like. Pull the rear carpet and padding out (you'll be surprised at how much more mechanical noise you can hear without all that stuff in the back) and go for a spin until everything is really warmed up. You might try a smooth road with a incline and go down in a low gear so the engine is doing the braking in the RPM range that it makes the noise.
Daniel Taylor
An Aussie in Alabama
1990 944 S2
Photodan is online now   Reply With Quote
Old 10-06-2009, 12:26 AM   #28
KevinD
KevinD's Avatar
Have you tried religion yet?
Sorry it wasn't the simple answer I had. I was so relieved it wasn't the pinion on my car. Sounds like yours could be, though. You've tried everything else! Damn, that has to be frustrating!
KevinD is offline   Reply With Quote
Tags
88, 951, 996, bellhousing, cabriolet, cam, catalytic, converter, gas, noise, pipe, porsche, rattle, rattling, start, tensioner, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
