1985 944, can't find source of leak
Have had my 944 in a couple of downpours but then yesterday I found water collecting in driverside footwell near the fender/door. Checked the sunroof drains, they drain well. Under hood drains are clear. Door seals seem good. Where do I look next?
Check your windshield seal. Push against the glass and see if there is any movement.
I'd be looking for cracked or failed seam sealer at all the spot welded body seams that are exposed to water. For water showing up in the kick panel, start at the firewall and cowl area. Be sure to keep the cowl area and drains clean. There are also cowl seams hidden by the fender. Leaks can also be from firewall seals for wiring harness, brake booster, etc. or door jamb seals at light switch and door wiring bellows.
Tiger03447 (11-07-2023)
Yes, patience is key. Best method for me has been removing interior paneling from the vicinity and exploring inside the car at the outset of a rain storm. With the driver seat removed, you can lay with your head in the footwell and hopefully watch it develop. Remember that where the water collects is rarely where the leak source is. Tissue paper can be a good tool for identifying the leak path.
Photos of the cowl well surface and firewall may help guide more specific advice.
