Drivers door switch
Drivers door switch
1987 924S my drivers door switch is broken, it is the push button that controls the interior light and key buzzer when the door is open. So I would like to replace it but I need to remove this panel, it has the hood and trunk opener on it. I cannot see any screws, is it glued in? I need to get to the plug on the back of the switch.
This side panel.
This side panel.
Remove the switch from the door jamb side. Recommend disconnecting the battery.
You sure? It fits through on the 944....
I just replaced mine on my 944 and it was tight and took a little wiggling but the plug came through the opening. I wouldn't think the 924 would be any different.
