Speed and Ref Sensor Removal Help
7th Gear
Hello all. I am performing the much dreaded speed and reference sensor replacement on my newly acquired 1983 base model 944. The car is currently in a no start condition (cranks but doesn't start) and all signs point to bad speed and reference sensors. So like everyone else I naively thought this would be an easy job... boy was I wrong. After about 3 hours and lots of pacing back and forth I only managed to break the head of the sensor clean off after trying to rotate it to break it loose, leaving only the shaft of the sensor in the hole. I tried everything to get mine out, it is incredible how jammed in there they are. I am at a loss for what to do here. My next idea would be to just try to remove the bracket entirely and get the sensors out from there. Is it possible for me to just remove the two screws holding on the bracket and pull it up and out? I really don't want to have to take the engine apart to get to these sensors as its not necessary.. but I am also willing to do that if there is no other way to get to them. I just want my baby to run.
You can get some ideas from the 928 board if you search there. It's a common problem with those cars, as well, and people have some pretty detailed writeups on what they've done to remove the CPS. I don't think you'll have to pull the engine.
Good luck
Good luck
Tiger03447 (03-14-2024)
Go to eBay and look at Porsche 944 sensor bracket you can get a look at the bracket as removed from the car. To remove the whole bracket you can try using two long extensions with Allen head sockets and try to remove the bracket. One bolt is a pivot bolt and the other is slotted so you can adjust the sensors. Try to get a lot of PB Blaster in there
Yes, do a search on all 944 boards. I have a 944 turbo and had already removed the intake manifold, alternator and turbo when I was doing the oil pan gasket. While I was in there I replaced both sensors which were jammed. I ultimately removed the sensor bracket, hammered the sensors out of the bracket from the underside after using PB blaster, cleaned the bracket and sensor sleeves and reinstalled. There was no way I could get enough leverage on the sensors without removing the bracket. And there was certainly not enough room to remove the bracket without removing at least the intake manifold. Tight quarters.
I posted my experience on the 944 turbo board, maybe that will be of help to you. Good luck.
The bracket can't lift up because of the dowel sleeve at the pivot bolt and it can't move rearward with the sensor in place because the sensor is through the window in the bellhousing. Once the sensor top is broken off and the engine is in the car, the options for removal are limited. With the bellhousing loosened and pulled back slightly, the sensor bracket comes rearward enough to be removed or save yourself some time and split the bracket with a chisel at the dowel sleeve.
l_juraschek (03-15-2024)
Reference sensors
To get mine out, I used a pair of about 12” ring nose pliers. After undoing the bolt, I was able to get the top of the sensor to break loose and turn with the pliers. Once that happened, they came right out with a bit of wiggling. Hope this helps some😀
I've posted this numerous times but here we go again. First PB Blaster, WD40 etc won't cut the crud that builds up on the sensors. Lacquer thinner or carb cleaner will dissolve the crud. Make this slide hammer tool out of vise grips, all thread, 1/2 pipe and a few nuts and washers. This tool will yank them right out. You might try running a screw down in the broken sensor to yank on.
7th Gear
7th Gear
