early speedometer to late transmission
I'm sure someone has asked this before, But is it possible/or has anyone done this. Hook a Late transmissions internal hall effect sensor to the early 944 speedometer. I know the 85.5 and up are electronic and 83-85 are cable driven.
Rainman
if you are removing your cable-drive/front left hub, this might be an option if you call them to sort out specifics.
https://www.dakotadigital.com/index....rod/prd886.htm
https://speedhut.com/categories/speedbox.html
