Front Coilover install (PICS!)
Hey Dave. Looks sharp, and easier than I would have expected, but I am a little confused. Do you have to cut the lower spring perch off, or did you do this just for cosmetic reasons?
Ok, I'm new to some of this I guess. The wider front rubber I get, but could someone elaborate on the ground control kit? Is this just the adjustable spring perch?
Mike, the GC parts are the threaded sleeve and perch, yes.
Dave, I'm not sure I'm the right gender to be saying this, but... you're rubber is on upside down The bump rubber goes the other way. No big deal, really - they still function that way. Great job!
Joe, nice dryer hose!
LOL Skip
Next time I have them off I'll make sure and fix that...assuming I ever take them off again. I'm sure they'll function better than my old bump rubber....remember those?
As soon as I touched them they disintegrated into about 6 billion pieces!
So yah like my hose ehh?
Originally Posted by tifosiman
Front's are Koni's with Paragon's GC kit, rears are KLA units that use a 2.5" spring as well. The KLA units are upside down, so that the spring is at the top, thus no rub on the trailing arm.
Hope that helps............
Jeremy
Jeremy
interesting that you got the KLA upside down!! does that mean your adjusting **** is at the bottom? this would be great if i could figure out how to do that!! do you have pics?
I just bought the same koni sport struts (used) and I am really wanting the coil over set up. But I have a couple of questions: Are 300# springs ok if I keep the stock torsion bars? I've been told that these are good for an otherwise stock 951 but I see that you've got the 300's with a much stiffer rear. What's a good spring rate if using stock torsions with Koni sports (@ full stiff) in the rear? Also, is there any cheap and easy way to get rear helper springs over the Koni sports that I've already got? (By the way it's an '86 951 with otherwise stock suspension.)
Thanks----
Thanks----
Former Sponsor
Here's a sneak peak.......
Thanks----
Thanks----
My other setup was 200# up front with stock torsion bars and full stiff Konis in the rear, and it was balanced perfectly. I have those 200# ones for sale if you want them. I also have the aluminum spacer that will change them from 1.25" drop up front to about .25" if you don't want to drop it much.
