Front Coilover install (PICS!)
#46
Originally Posted by dave120
If you put 300# on the front with stock torsion bars, it's going to understeer badly. Some guys on here actually use an even bigger 29mm torsion in the rear, but 28 seems pretty balanced with my current setup of sway bars and shock stiffness.
My other setup was 200# up front with stock torsion bars and full stiff Konis in the rear, and it was balanced perfectly. I have those 200# ones for sale if you want them. I also have the aluminum spacer that will change them from 1.25" drop up front to about .25" if you don't want to drop it much.
#48
Originally Posted by bader$
Will those work on a 88 944s with factory struts, and are they the ones that lower the front 1" or so? If they will work how much do you want for them?
