MSD Blaster 2 Impressions
I just installed the Blaster 2 coil last night and I am really happy with the results.
The first thing I noticed is that on startup its just starts right up. This is compared to what happend on my old coil when the car would fire a few times then die or fire and start on 3cylinders and then finally after a few seconds of misfireing the engine would come to life.
I have not been able to drive the car yet but after how well the car is starting I am sure my old coil was dieing.
Whoa.... I just installed a Blaster2 lastnight as well. I still have to get around to putting in that damn ballast resistor, gotta figure out a decent spot to mount it. Ive already driven my car, seems to rev nicer with a little bit more lowdown... Might just be my mind tho
Just got to drive my car a bit more with it, quite an improvement. The engine feels and sounds smoother at higher RPMs and has more low down power, not a ton but its noticble. Its better at 1000RPM, that area, as in getting the car moving.
Im going to do the ballast resistor in a few minutes, but I should think that ANY stock car needs it, thats what the instructions say. The primary coil is a lower resistance. The resister is a few bucks from the store, it would be hard to get it cheaper as its a low value resistor with a high current handling ability (its a large ceramic resitor).
