KLA solid upp strut mount?
Do these come with all the hardware needed? What stock hardware is retained?
Also, how easily is camber adjusted? I am trying to decide between these, the Ground Control/Paragon camber plates and the Racer's Edge camber plates.
Max
Max
Former Sponsor
Originally Posted by 97xray
Ken, thanks for the explanation (I'm ignorant to these issues!).
Any thoughts on the 55-65mph sutter being addressed, at least partially, by the solid mount?
Former Sponsor
Originally Posted by streckfu's951
Scott,
You keep coming up with ways that motivate me sto spend my money. Damn
Hey! I didn't take your money yesterday. But, today is a different day......
Former Sponsor
Max
Max
YET! You didn't take it yet.
And that conversation was only about the rear shocks. I'm also planning for other things you sell.
1 Post
I just recently upgraded to the turbo strut/koni inserts with the later upper mounts. My concern with these solid mounts is that the axis of rotation for the entire macpherson strut does not exactly line up with the strut axis, as the positon of the lower ball-joint is off-axis. (see the pic) In fact I noticed that the rubber of the upper mount flexed as the wheels turned due to this fact. If the upper bearing is spherical it would solve the problem, otherwise I think over time it would fail.
Former Sponsor
Originally Posted by Lousailor
Duh, just reread the description. Any way you guys could post a cut-away drawing on the web site to show the construction highlights?
Derek,
The gains are in the handling. The gain in handling on a car will bepend on how good (or bad) your rubber uppers are. The more warn the uppers the more you will feel the gain. Beyond that, you will also have a lifetime upper that at most you will have to replace a bearing at a cost of about $28.00.
This upper solves two problems, 1. Flex during hard cornering and 2. High cost of OEM mounts.
Ken
Ken
