968 Mirrors Help!!
Old 05-28-2011, 02:13 PM
  #31
RDL
RDL's Avatar
Robby, PM sent.
Old 10-21-2012, 09:03 AM
  #32
davkle
Cruisin'
davkle's Avatar
I cannot seem to be able to fully compress the mirror springs with the 14mm hex tool - way way too stiff... and having problems also using the bolt and nuts gizmo... I'm using metric parts, hence M12 which fits well down the centrehole of the spring assembly, but don't really have the space to fit the nut inside the mirror, once I have fit the spacer and the washer... :s
Old 10-21-2012, 12:31 PM
  #33
davkle
Cruisin'
davkle's Avatar
I stand corrected. As you push, just when you think that vein in the right hemisphere of your brain is about to pop, you can turn it and lock it.
Old 10-21-2012, 02:33 PM
  #34
951Boost
951Boost's Avatar
Yeah the eye bolt "special tool" is the bomb, works well. Still takes a bit of muscle tho.
Old 10-21-2012, 06:54 PM
  #35
davkle
Cruisin'
davkle's Avatar
I used a 14mm hex key at the end of a T-shaped handle. Because currently I don't have access to a bench vice, I pushed the mirror assembly against the chest whilst compressing the spring. Not recommended. But it got the job done.
Quick Reply: 968 Mirrors Help!!
