Can a Bad Control Arm - Catastrophic Failure/Accident?
Old 12-25-2004, 09:24 PM
  #31
Oddjob
Oddjob's Avatar
Originally Posted by pcarfan944
Jonathan- what kind of symptoms did you get with your bad control arm?
My car makes a grinding type sound from the front of the car sometimes when I make speedy left turns. . Won't hear it at all if i'm turning right. Thought maybe that could be something related to ball joints/control arms/wheel bearings or maybe something completely different.
Anybody have any ideas? Oh..and Merry Christmas!
Typically a ball joint that that is really shot will tend to bind and release in the socket. So you will get a popping noise and feel from it. Seems to be most noticeable making sharp show speed turns, like in parking lots and in and out of the driveway. It will feel like someone hit the control arm with a ballpeen hammer.
If youre getting a grinding noise and feel while turning, it is most likely a wheel bearing.
Old 12-25-2004, 10:50 PM
  #32
AznDrgn
AznDrgn's Avatar
Jonathan I'll be back at the end of January. Shock options will depend on what you want to do to the car and how deep your pockets are. I think the most likely suggestions for you would be bilsteins or maybe some koni's but I hear the koni's wear out every 2 or 3 years where as the bilsteins will last a lot longer.
Old 06-11-2016, 05:43 PM
  #33
mcod
3rd Gear
mcod's Avatar
I have a question about this - my daughter had her control arm replaced recently, and 2 days later had a bad accident where the tire tore off as they were on a freeway onramp - luckily no one was badly injured, but the car was totaled. Does this sound like there could have been a mistake made when they installed the new control arm? It was the same spot (driver's front) that had been repaired...
Old 06-11-2016, 07:20 PM
  #34
shortyboy
shortyboy's Avatar
If they overlooked either torque specs or the pinch bolt for the control arm bushings to hub then it's likely after hitting a bump, it disconnected itself from the control arm. I had a ball joint failure earlier this year. Ball joint ripped out of the aluminum socket. Luckily it was at low speed and minimal damage. No other cars involved. I would investigate of possible.
  #35
shortyboy
shortyboy's Avatar
Btw, what year car? Any pictures?
Old 06-11-2016, 11:03 PM
  #36
mcod
3rd Gear
mcod's Avatar
Default Thanks
thanks for the quick reply 2007 Chevy HHR here's what happened to the tire:
Old 06-14-2016, 01:35 AM
  #37
VirginiaF1
VirginiaF1's Avatar
Glad she is OK!
Are those Fuchs?
Old 06-15-2016, 02:09 AM
  #38
mcod
3rd Gear
mcod's Avatar
Originally Posted by VirginiaF1
Glad she is OK!
Are those Fuchs?
I have no idea what that is, sorry!
Quick Reply: Can a Bad Control Arm - Catastrophic Failure/Accident?
