Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 01-15-2005, 02:52 PM   #1
wombat7
wombat7's Avatar
Send a message via AIM to wombat7
Default Help my car squeals when its cold
When I start my car when its cold, I get a squealing sound from the engine bay. It sounds like a belt, but doesn't seem like it is. I've checked the belt tension and they are fine. When the car runs for a little bit the squealing stops and it seems like a belt wouldn't stop squealing. I've run out of ideas. Does anyone know what this squealing could be??
To remove this ad, register today or login if you already are registered!
wombat7 is offline   Reply With Quote
Old 01-15-2005, 03:18 PM   #2
Epic2112
Epic2112's Avatar
kevinkesler
Send a message via ICQ to Epic2112 Send a message via AIM to Epic2112
I say belt. As the car warms up the engine expands, putting more tension on the belt.
Kevin
1989 951, Leinengrau Metallic - 1986 Engine, K27/6, Lindsey Stage 2 MAF, Seimens 55lb injectors, TiAL 38mm, LBE, Vitesse Software, Himsel Haus Fuel Lines (Happy?), 3 bar FPR, SPEC Stage II Clutch, Fabspeed SS 3" Exhaust, 33/5 Bias Valve, Uego WBO2, VDO EGT, KLA Strut Brace, Loose nut behind the wheel.
1990 M3, Sterlingsilber Metallic
1991 Volvo 245SE, Vit
Silly Hats Only...
Epic2112 is offline   Reply With Quote
Old 01-15-2005, 03:25 PM   #3
JustinL
JustinL's Avatar
As the belt warms up it will get stickier too and stop squeeling. If your tension is good on the belts then it may be time to replace.
HTH
Justin
88 Turbo S SilverRose Megasquirted K27/6 (Weekend cruiser)
89 S2 with 968 engine (Racecar)
02 E46 M3 (daily driver)
08 VW Touareg (TowRig)
JustinL is offline   Reply With Quote
Old 01-15-2005, 04:10 PM   #4
Scootin159
Super User
Scootin159's Avatar
An easy way to check the belts (and figure out which one it is):
Next time it squeals...look at your volt meter on the dash...if it reads 12v during the squeal and then jumps quickly to ~13-14v after the squeal....it's the altenator belt.
If it only happens while turning the wheel...power steering belt.
You want 5mm of deflection on either belt between the crank & either the A/C pulley or the power steering pulley (depending on the belt). Use a straight edge & push up on the belt as hard as you can to measure the deflection. If you do that & it still squeels....time for new belts.
Scootin159 is offline   Reply With Quote
Old 01-15-2005, 04:21 PM   #5
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Send a message via ICQ to hosrom_951 Send a message via MSN to hosrom_951
You may have a pig hiding behind the alternator
Seriously, double check your belt(both p/s and a/c-alt)
Hussam Jamil <- Why is my name here?
RLM#:040430-3502
'86 944 Turbo-German Spec (In Dubai)
'96 BMW 328is-Japan Spec (Sold)
'06 BMW 325i-Gulf Spec (In Dubai)
'12 BMW 530i - German Spec (In Germany)
'13 BMW 530 - Gulf Spec (In Dubai)
hosrom_951 is offline   Reply With Quote
Old 01-15-2005, 05:59 PM   #6
wombat7
wombat7's Avatar
I thought it could be a pig... maybe that's why my car is so slow, I've got pigs hiding in my engine... or it could be because I don't have one of those whiney things you 951 guys have...
I'll have to check my belts again I guess...
Thanks guys...
Old 01-15-2005, 06:08 PM   #7
Peckster
Super User
Peckster's Avatar
Could be a bad alternator bearing or something like that, but probably a cold loose belt. Try tightening them a little to see if it stops.
Peckster is offline   Reply With Quote
Old 01-15-2005, 06:47 PM   #8
Rock
Lazer Beam Shooter
Rock's Avatar
Send a message via AIM to Rock
Mine squealed when cold, it also squealed a lot when cold and i turned on the heat.
I ran it for about a month like this, and lost the alternator belt at the side of the road.
Luckily I lost it right in front of an auto parts store. Luckily they had an alternator belt for me. I changed it, no more sqeualing and the voltage stays nice and high.
Rock is offline   Reply With Quote
Old 01-15-2005, 08:09 PM   #9
chitown928s4
User
chitown928s4's Avatar
Ok...mine does this only when its wet outside and only when i trun on the defrost or heater. If i turn on the defrost or heater when its wet out side it starts sqealing right away. But only when it rains. Not when its dry. Like today subzero weather and it didnt sqeal. Is that normally. Also my fvolyage metter drops to like 10 if i have both items on. Usually at idle im at 14 then 12 with the heat and 10 with heat and defrost. Is this all normal. Thanks in advance.
chitown928s4 is offline   Reply With Quote
Old 01-16-2005, 04:39 PM   #10
Scootin159
Super User
Scootin159's Avatar
Quote:
With a proerly working altenator (which requires a properly operating belt) you should see 14v (actually 13.7v I think..) whenever the engine is running. If you turn on the heat/ac/whatever, it should still say 14v. If you get enough things running, obviously it will draw more electricty, and thus possibly lower the voltage a noticeable amount....but unless you have a 1000w stereo in your car, you shouldn't be able to tell the difference.
My course of action would be (stopping once the problem dissapeared):
1) check the Altenator belt tightness
2) replace the altenator belt
3) check the altenator itself (voltage regulator, etc.)
Paid Advertisement
Tags
belt, car, cold, heat, heater, impreza, squeaks, squeals, squeek, squeels, squels, subaru, turn, turned, wrx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
