Looking for rear control arm. My friend takes a corner too fast in his 944...
and ends up pulling a Campeck. It was all curb, and left his left rear wheel at an, um, disadvantage. One would think he had never seen a decent car before. He knows better, and now has to pay (and put up with my non-stop crap). The questions are:
1) The control arm is slightly bent, are late and early rear arms different? I suspect so, but if anyone can confirm it would help.
2) He'll need a black cookie cutter too.
3) Anyone have these parts?
edited to remove a certain reference to a low spot *next* to a road.
Wow, he bent a rear trailing arm? I would be looking to see what else got bent. Takes quite a bit of force to bend the trailing arms.
Early and late arms are different, early's are steel, late's are aluminum. Specs-wise, they are the same, but the wheel bearings are different. Would be best to stick with an early arm though.
yes, a Stupid hat sounds good. He blames it on the tires, but I know better. I daily drive mine, he doesn't. As a matter of fact, he has only put about 300 miles on his.
Originally Posted by Campeck
HAHA...your in luck. I have one.......
AND a cookie cutter.
now if you could just stop the hatin' i might send 'em your way.
Anyway, YGPM.
Originally Posted by TheStig
Hey guys just remember, when he turns 30, it'll all be over He'll be curbing a minivan
You know this guy? He will prolly spin the thing around 3-4 times doing it too.
edit: My friend, not someone here.
