Flywheel Bolt Size?
Flywheel Bolt Size?
Just have to go to the store for some bolts and also need the serrated wrench for the flywheel, anyone know the size off hand? I'd prefer to just get the size I need as noone seems to have actual sets...
Just get them from Paragon. I don't know if they'd have the cheesehead tool, but you could ask. I got mine from Snap-On. As much of a PITA a clutch job is, I wouldn't dick around with some unknown off-the-shelf bolts.
12mm 12 points (i think... or was that 10 mm... I know the CV joints are 8 mm 12 points). These are the head sizes. Not sure of the threads.
I have re used flywheel bolts without any issues.
The cheesehead tool is 12mm and the bolt-thread is 10x1.25mm. When I put my flywheel back on, I just got some grade-8 flanged hex-head bolts and used a normal socket.
Thanks yeah i was just asking hte head size, i ended up guessing at NAPA, considering there was only two sizes, the one for teh cv's and the bigger one, so i guessed that and it worked. Thanks again, btw it is 12mm
