classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#46 | |
Over the Cliff
Rennlist Member Join Date: May 2004
Quote:
I'll most likely race the GTS challenge with NASA since they have the most races in the southeast. I will likely run a race or two with PCA, then I'll be in the GT3S class and have to run with the turbos Chris - I doubt that I'll go widebody. I put a pair if 17x9 running 255's on yesterday and they should work with a little fending roll Ok, a lot of fender roll
Tim '95 968 Coupe (White/Cashmere) '88 92468?? (NASA GTS3, PCA GT4S, PBOC R4) Thanks to www.discoveryparts.com, the Hoosier Tire Contingency Program, and www.autowhiz.biz!!!!!!!
#47 |
Rennlist Member |
Good your not going widebody!!! Killing them softly....
Ian G. (20) <----Why is my name here? 1990 Volvo 740 GL, 5 speed, Mid Blue metallic on Black leather. Affectionately named "/b/" Become a Rennlist Member today! <---Click![/size] Avatar: Tuesday Marie |
#48 |
Nerd Herder
Rennlist Member Join Date: Feb 2002
FWIW, the 16x6/7 Boxster wheels I had with 235/255's did rub on the rear, even after some rolling.
Them hips is skinny back there!! I'd love to see this when it's done..
What signature? |
#49 |
Over the Cliff
Lunch break, so I thought I'd upload a pic of the manual steering rack.
#50 |
Rennlist Member Join Date: Jun 2003
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Tim, I just noticed the thread -- I've been out of the loop for most of the summer -- looks like you got a great project in the works!
For what it's worth, when I dropped a 968 engine into my '87na, we kept the original brake booster (girling, 944.355.011.10). "We" being my mechanic and I -- I ended up having to employ some professional help. The motor fit with about half an inch space all around the brake booster/master cylinder. Is there a difference between the engine compartment of a 944na and a 924S? Or it is possible that the motor is sitting too high? That indentation in the manifold should indicate where the master goes.
Joe Chen <- Why is my name here? Current fleet: * '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) * '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car * '88 Silberossa 951S "Rosy" - garage queen * '99 Ford Ranger - Porsche support vehicle * '01 Kawi ZX6R * Secret project Former cars: * '94 Black 968 Cab "Steffi" (totaled) ![]() * '87 Nautic Blue 944 S3 "Emma" (blown motor) ![]() * White 944S2 * parts cars... |
#51 |
User
I think I know why you are having problems. In the early cars and 924S the firewall and booster/MC mountings are a little different than on the later cars. IIRC they redesigned teh firewall and moved the MC and booster over and up a little bit. I noticed this when I took a chunk of an S2 firewall to patch an early 944 firewall. If I'm right the turbo booster and MC you just bought won't do you any good at all and you'll either have to shift the booster/MC or look into something like a hydro boost MC.
#52 | |
Over the Cliff
Quote:
#53 |
User
Have you measured out your 968 intake? I still have an S2 manifold kicking around and I don't remember it having that indention in it so it might be a little smaller so you can get clearance.
#54 | |
Over the Cliff
Quote:
#55 | |
Over the Cliff
Quote:
#56 |
Over the Cliff
I think I have it, I moved the brakebooster up 2cm and it seems to fit
#57 |
User
Congratulation for the work and good luck for the future
#58 |
Congrats!
#59 |
User
Sounds good, just make sure you reinforce the new holes so the bolts don't pull through.
#60 | |||
In the Sink
Rennlist Member Join Date: May 2003
Quote:
Will the hood close with the reservoir installed?
Kevin '87 924s Quote:
Quote:
| Tags |
| 944, 968, changesdoc, hoosier, kfp, pads, renton, tire, wa, wiring |
| Thread Tools | |
