Busted 3rd Gear in the Turbo Cab!
About a month ago I went out driving with some other Porsches. On the highway at over 130 mph I put quite a bit of stress on the gears, downshifting to third and flooring it to get maximum acceleration. The 951 is geared so long that even though 3rd seems short, it actually was not.
Drove back home about 60 miles without a problem. Parked the car and the following day I went to get some new rear tires and as I was driving through town slowly I suddenly heard a pop from the back of the car and a constant clicking sound.
At first I thought it might be a CV joint but then I narrowed it down to 3rd gear. My guess was confirmed when I eventually I saw the wreckage...
The car is repaired now, and 3rd gear is as good as it ever was with a new synchro ring and needle bearings, but I wonder what may have caused this. The gears didn't grind when I downshifted. I just put a lot of pressure on the car to accelerate, but would that cause a pinion to break three teeth like mine did?
It's hard to say Luis. It may be that a small crack at the root of one (or more) gear teeth slowly propagated until a high stress event was enough to pop it. It might be interesting to have the gear magnafluxed to see if there are any cracks in the other gear teeth. I could be a defective heat treatment on the gear teeth...
So-o-o, at 130 mph, you downshifted to accelerate? 130 mph in a 951 tranny equates to over 8000 rpm. Sounds to me that you're damn lucky you didn'y grenade that 4-holer, or lock up the rears and kill yourself! Jeeeze!
Budding Photographer
Originally Posted by Campeck
yeah. third gear in the NA hits 80 mph. i doubt it hits 130 even on a turbo. you didnt mention if you overrevved it or not.
