Woe is me, aka oil pan guidance
Old 11-30-2005, 05:19 PM
'88-924S
'88-924S's Avatar
Default Woe is me, aka oil pan guidance
It's been quite a while since I've been on - Katrina turned my life upside down for several months. No sob story here--the Porsche was spared!! However - I had to load her up to the brim and on the way to Seattle & I hit a speed bump and cracked the oilpan. No leakage or 'break'. However it'll need to be fixed replaced. Pictures show it pretty well. Can I remove this and get it welded or do I need to find a replacement oil pan? I'm just about busted with money and spent some of my last on getting the old girl up to snuff. So any and all suggestions are welcome.
I don't think I'll be able to pay to get this done - but for future reference can anyone refer me to a good shop in the Seattle area?
BTW - I don't know if I'm paid up on dues - not on the top of my list right now - but I'll renew eventually, so please don't ignore this post if my membership has elapsed.
TIA
Old 11-30-2005, 05:28 PM
'88-924S
'88-924S's Avatar
Default Oil Pan pictures
TIA
Old 11-30-2005, 05:35 PM
Yabo
Yabo's Avatar
beware, it's a big job when the engine is in the car. Look at this thread, and the link to danno's instructions in it especially since youa re doing it in the car.. I just did the job this weekend but it was out of the car so it is simpler.
https://rennlist.com/forums/showthre...&highlight=pan
Old 11-30-2005, 05:42 PM
SamGrant951
SamGrant951's Avatar
Buy another oilpan, they are cheap. I got a super nice condition pan for $35.00 off ebay. Might as well do the rod bearings if they havent been done yet. (With those buy new rod nuts as well.)
Sorry to hear about your misfortune but good luck and welcome back.
Old 11-30-2005, 06:04 PM
theedge
theedge's Avatar
Does the damage go down to the pan itself? The fins dont have oil inside of them, so if the damage is limited to just the fins then you dont have to worry right now.
Old 11-30-2005, 08:46 PM
'88-924S
'88-924S's Avatar
The damage seems to be into the pan itself - don't know how thick the pan is - it's significant though.
Old 11-30-2005, 09:08 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
dont risk it- replace the pan. They are pretty cheap considering the cost of normal replacement parts..
It IS a PITA- I did my oil pan gasket in the gravel driveway.. without removing the engine.
3 full days of crawling under jackstands is not pretty.
Old 11-30-2005, 09:21 PM
michaelathome
michaelathome's Avatar
Get hold of Jason 951 or Granite 944. They may have the parts and I am sure might help. I think that Jasons wife is due soon so he could have his hands full
Michael
Old 11-30-2005, 10:08 PM
'88-924S
'88-924S's Avatar
chris_924s--NOT what I wanted to hear - I used to read those venting posts and just not understand how someone could get so frustrated with repair after repair - well I do now! What is the tedium on the job? I know it's quite a few bolts - but what makes the job so hard? Lack of space?(as always!) Thanks for the replies.
BTW - If I'm not mistaken the a-arms have to come off - will I need an alignment afterwards?
Old 11-30-2005, 10:16 PM
Yabo
Yabo's Avatar
I told you that too.
i think its generally 10-12 hour job at least the first time..
Old 11-30-2005, 10:39 PM
ahofam123
ahofam123's Avatar
You will have to remove the entire cross member to get the oil pan off (entails supporting the engine from above with either a hoist or a homemade support made by 4x4). Clarks garage has a pretty good write up on it. You should get an alignment done to it after you finish, but if you put everything back to where it was (mark the threads with white out or paint), you can postpone it until you earn some more cash.
Old 11-30-2005, 11:37 PM
Mike C.
Mike C.'s Avatar
If it isn't leaking oil then I really doubt you need to do anything. I suppose it wouldn't hurt to put some JB weld or equivalent on there. Removing the oil pan with the engine in the car is not my idea of fun....
Old 12-01-2005, 01:58 AM
'88-924S
'88-924S's Avatar
After all the time and $$ I don't want to risk a major oil leak and potentially put the entire motor at risk.
Old 12-01-2005, 02:57 AM
shmucklebuckle
shmucklebuckle's Avatar
Nothing against you Mike, but 88 924s, please do not "hack" this job or anything else of this nature on your car. If you want to repair the pan, get the crack ground out at a 45* angle and TIG it back together. JB Weld/Quik...gawd. It's good for...um...well...hack repairs, like mashing over a leak in your radiator, so you can drive to the radiator shop or your house. Do it right, you know you want to!
Old 12-01-2005, 03:14 PM
'88-924S
'88-924S's Avatar
No no, I don't want to do it right.! I want to do something quick and easy and then drive the thing!!
I'll do it right though, out of duty and hope for uninterrupted bliss with the car.
Quick Reply: Woe is me, aka oil pan guidance
