Brake problem
Old 03-26-2006, 02:23 AM
jeeper31
jeeper31's Avatar
Default Brake problem
I just replaced front and rear brake pads and changed the brake fluid using a power bleeder. the problem is now the brake pedal travels to low before the brakes engage. It's a litle freaky. What's the deal?
Old 03-26-2006, 10:02 AM
jeeper31
jeeper31's Avatar
Rebled the rear and still happening. Starting to hate working on this car.
Old 03-26-2006, 10:21 AM
Lemming
Lemming's Avatar
Sounds like you have air in the system. When you say bled, how much did you run through the system?
Old 03-26-2006, 10:43 AM
jeeper31
jeeper31's Avatar
I changed all the fluid. From what I can tell there were no bubbles. How much should you run through?
Old 03-26-2006, 10:50 AM
Lemming
Lemming's Avatar
Before a track weekend, I'll put through about 1/2+ can of ATE Blue.
Old 03-26-2006, 10:52 AM
jeeper31
jeeper31's Avatar
I used almost a whole can
Old 03-26-2006, 10:58 AM
xsboost90
xsboost90's Avatar
may have to manually bleed them, get a pumper person in the drivers seat, start at the furthest wheel and get closer-to the mc.
Old 03-26-2006, 11:02 AM
jeeper31
jeeper31's Avatar
was thinking that. how much do they pump?
Old 03-26-2006, 12:00 PM
jeeper31
jeeper31's Avatar
RE-bled all corners and no difference. Looks like there might be tiny bubbles in the right front that I can't get rid of.
Old 04-01-2006, 01:17 PM
jeeper31
jeeper31's Avatar
Brought car in to mechanic and they bled brakes. Said was a lot of air in right rear. Brakes are still not good. checked for leaks under dash by brake and clutch, nothing, looked for leaks around resevoir and MC found nothing. Any ideas? Mechanic said it could be the pads.
Old 04-01-2006, 01:25 PM
shiners780
shiners780's Avatar
How old are your brake flex hoses (the small hoses that run from the solid lines to the calipers)?
Look for buldges. Squeeze them and see if you can find any soft spots. Have some else press the brake pedal and watch the hoses and see if they are expanding anywhere. Could be that some of the pressure is being displaced by a soft spot, causing the hose to expand?
I dunno, just a thought.
Old 04-01-2006, 01:29 PM
jeeper31
jeeper31's Avatar
sounde like a good thought and will check it out although this problem has happened suddenly as soon as I changed the pads and fluid.
Old 04-01-2006, 02:11 PM
AR10
AR10's Avatar
Sounds like you have got all the air out so I would
recheck all the things you had apart. Look for binding pads,
sprung calipers, loose wheel bearings, things like that.
Good luck
Old 04-01-2006, 02:57 PM
jeeper31
jeeper31's Avatar
What do you mean by binding pads? I was thinking about putting the old pads back in to see how it felt. Bearings are good.
Old 04-01-2006, 03:21 PM
AR10
AR10's Avatar
Something is causing the pads to need to move too much to touch the
rotor on one or more wheels. Make sure the clips and retainers are installed
correctly.
Quick Reply: Brake problem
