Rear seat delete begun-not the usual method
#46
I am also working on this, but in making a usable top hinged storage space rather than a speaker box. Because I am **** about the details and flat out refuse to do anything irreversible to the car, it is taking time.
#47
#48
Originally Posted by KuHL 951
I'm not sure if there is any interest but I was considering selling a kit with the wood all cut, holes drilled, assembled, and all padding/carpet precut for immediate installation as a unit. Options could be solid front, vented front, or speaker cutouts. I figure the kits will weigh about 12-14 pounds. Any thoughts on that idea?
As for a kit all ready to install, I'm sure there would be plenty of interest on these boards and on Pelican.
#49
Any ballpark idea what you'd be charging for the kits? If the price is resonable I would be interested since some ******* stole my table saw and alot of my wood working equipment.
#50
Steve- that's beautiful... you could definately sell some kits of that....
Can you get me in touch w/the same guy on the Nuprene? How thick is it? The Neoprene I have is >1/2" thick & weighs next to nothing. Also, which of the Nuprene style would you recommend for me since you know what I'm trying to do...? You know, hear a pin drop at 150mph...
Oh yeah, in several of the pics, you have the top panel w/the amps attached, flipped upright & held up by the big bolts in the sides of the panels that held the seatback up... This is the way you plan to keep this, right.....? And that is the reason why you did the wooden back FROM the seats, so you could keep it hinged, easily, etc, right...? This is one thing I wasn't 100% clear on.... if ripping a rear seat apart for that was more for ease of fitment (so you didn't have to cut something else), or filp-up ability or BOTH...? Either way, it's really looking good & I'd say it's lighter than any of the CS style backs too as they used really thick particle board type wood- the 968Cab thing weighs almost as much as the entire rear seat assembly w/belts, etc- too bad b/c they're really cool & that hollow little metal rail is perfect to keep things from sliding forward.
thanks
thanks
#51
Hey Man
Originally Posted by Robby
..Can you get me in touch w/the same guy on the Nuprene? How thick is it? The Neoprene I have is >1/2" thick & weighs next to nothing. Also, which of the Nuprene style would you recommend for me since you know what I'm trying to do...? You know, hear a pin drop at 150mph...
Oh yeah, in several of the pics, you have the top panel w/the amps attached, flipped upright & held up by the big bolts in the sides of the panels that held the seatback up... This is the way you plan to keep this, right.....? And that is the reason why you did the wooden back FROM the seats, so you could keep it hinged, easily, etc, right...? This is one thing I wasn't 100% clear on.... if ripping a rear seat apart for that was more for ease of fitment (so you didn't have to cut something else), or filp-up ability or BOTH...? thanks
BTW: For a good un-biased non-scientific evaluation of sounding proffing in a car the link below is a good read. Roby, your Polyken product came out very well!
Soundeadener Showdown
#53
Hey Man
That's a cool article... pretty long- will have to finish it later- I skimmed through some parts... which would you say is the same as the Polyken?
A combo of both should be great. I used the thicker foil-faced padding for sound and heat puposes under the carpeted areas including the hatch area. Call me cheap but most bulk soundproofing materials can be found in for much less from other sources without all the labeling and brand name hype.
#54
I just nearly finished up my own enclosure. Fiber glassed a sub box into rear seat(MInus seats). Looks great. I will post a thread with all steps soon! Bumps like hell also!
#55
Hey Man
