No start, no sell...
Old 10-09-2006, 06:04 PM
MY83944
MY83944's Avatar
Default No start, no sell...
Well, never sold the 944 and never tried real hard.
My gosh the 944 is a wicked drug . . .
Anyway, I am nearing the point of actually wanting to get it running again and need some help.
Car will not start, cranks over, seems to fire until it starts and when you turn the key back to let it run it dies.
Something simple?
Many TIA
Old 10-10-2006, 12:08 AM
Supachink
Supachink's Avatar
reference sensor?
Old 10-10-2006, 12:29 AM
SidViscous
Big thirst, Sore Thumbs
Napoleon
SidViscous's Avatar
Check for leaks around the intake boot, loose fittings and the like.
Old 10-10-2006, 08:54 PM
MY83944
MY83944's Avatar
reference sensor is likely - I need to test it.
thx!
I'll also double check all boots while I'm at it
Old 10-10-2006, 09:05 PM
Dan87951
Dan87951's Avatar
Does the tach bounce when you crank the car? If so you are getting a signal from the speed/reference sensors.
Old 10-10-2006, 10:26 PM
MM951
MM951's Avatar
Think you have a massive vac leak. If you floor it while cranking does it fire up?? Check your j-boot for tears etc
Old 10-10-2006, 10:40 PM
xsboost90
xsboost90's Avatar
ignition switch? read your post!
Old 10-10-2006, 10:51 PM
mrmunky
mrmunky's Avatar
having a similar problem.. ref sensor is up first
Old 10-11-2006, 01:42 AM
Legoland951
Legoland951's Avatar
Electrical portion of the ignition switch from what you are describing. They crack in almost all early 944s as just about every parts car I had had cracked plastic housings on the switch. When the crack gets really bad, the contacts will no longer line up thus causing no power to the "on" position after you start the car.
Classic sympton: Car will start and run great while the key is on the "start" cranking position EVERYTIME but once you let the key go to settle in the "on" position, the car dies.
$19 fix.
Old 10-11-2006, 10:29 PM
MY83944
MY83944's Avatar
Sheit, the ignition switch is new . . .
Tach bounces -
All boots are new, replaced many moons ago -
Shall proceed with investigation pointed towards ignition switch
THANKS!
Old 10-11-2006, 11:10 PM
Legoland951
When did you replace the ignition switch? Did you have the same symptoms before or did you have to rekey your ignition switch due to theft or something?
Old 10-12-2006, 02:16 PM
MY83944
MY83944's Avatar
Before, I had to kind of jingle the key to make it work. After the new switch, it worked great, no issues.
Then one day, out of the blue, the car would not start and here I sit.
Well, it was not out of the blue. My other vehicle was loaned out and there was a really bad thunderstorm going on outside. I was late to work and had to ride my motorcycle in the storm. As I was late, I wore my shorts and stuff, then rode well in excess of 100MPH, lane splitting all the way.
I sold the motorcycle shortly afterward . . .
Anyway, everything worked fine until the morning it would not start.
I did find one suspect ground, on the bellhousing. Moved it to the head.
Hope it is the switch, that would be sweet!
I have one on order, should be here by the weekend.
Old 10-12-2006, 02:50 PM
gtroth
gtroth's Avatar
...I seem to remember reading that the "starts and immediatly dies" problem is the AFM (i.e. unplugged, etc.).
Old 10-12-2006, 02:57 PM
quinnfiske
quinnfiske's Avatar
Might be the DME relay also. It enables both the DME itself and the fuel pump as well. Clark's Garage has a proceedure for jumpering it out to test it.
Old 10-12-2006, 09:37 PM
gtroth
gtroth's Avatar
You moved the bell housing ground to the head?
Quick Reply: No start, no sell...
