Need small part bad
Registered User
Need small part bad
Do any of you guys have the hex bolts that hold the seats down??If you have any parts cars with these I would gladly buy them from you.I ruined mine and my seats are sliding back and forth.That cant be to safe Id appreciate anything you can do..
Lifetime Member
Lifetime Member
Fix this ASAP. If you drive too long with loose/missing bolts you stand a chance of tearing the floorboard open. BTDT. Now the '84 has two bolts on the drivers seat that go through the floorboard with BIG fender washers on the underside of the car .
(Nuts too !!)
(Nuts too !!)
Rennlist Lifetime Member
Make sure you get the correct grade of bolts if you buy them at Lowes or any other place...this is not where you want low quality hardware. I can't recall but I believe that that these are at least an 8.8 grade bolt (perhaps someone has one in hand & can verify by the marks on the head) but may be a grade 10 bolt.
