headgasket on hold: stripped 5mm hex bolt, how to get out?
Old 01-15-2007, 08:55 PM
billthe3
billthe3's Avatar
Default headgasket on hold: stripped 5mm hex bolt, how to get out?
Yeah, any help would be appreciated.
One of the damn 5mm hex bolts that holds on the intake manifold has stripped, so I'm sort of stuck in the teardown process until I can get this thing out. I already tried using a torx bit to see if that would get grip (no), and the positioning of the bolt won't let me hack a slit in it with a grinder to use a screw driver to get it out.
Old 01-15-2007, 09:04 PM
tod84944
tod84944's Avatar
You will probley have to drill the head off.
Old 01-15-2007, 09:08 PM
75ohm
Resistance is Futile
75ohm's Avatar
Get a bolt extractor, not an easy out.
Old 01-15-2007, 09:10 PM
75ohm
75ohm's Avatar
Click Here!
Old 01-15-2007, 09:35 PM
MAD MAC
MAD MAC's Avatar
Sheet metal guys are known to weld an extra nut onto the stripped bolt. If you can carefully get to it.
Old 01-15-2007, 10:20 PM
Legoland951
Legoland951's Avatar
Its probably easiest to drill the head off the manifold bolt as there is not a whole lot of room in there.
Old 01-15-2007, 11:09 PM
PorscheDoc
PorscheDoc's Avatar
The bolt head will drill off very easily.
Old 01-15-2007, 11:29 PM
sm
sm's Avatar
Originally Posted by 75ohm
+1 on this idea.
Old 01-16-2007, 02:46 AM
Granite 944
Granite 944's Avatar
Originally Posted by sm
+1 on this idea.
Sorry, my vote would be -1000, unless your fully familiar with the limitations this type of tooling has, and the experiences of using such.
Drill the head off. THAT in itself, is enough challenge, if ya haven't done this sort of thing before. Good luck!!
Old 01-16-2007, 03:45 AM
billthe3
billthe3's Avatar
Cool, thanks for the opinions everyone. I ended up getting a set of these http://www.sears.com/sr/javasr/produ...cemldffidfmm.0 , so I'll see if they work tomorrow. I was too pissed off about sears not having all the sockets I wanted to buy (5mm, 6mm allen head socket) and didn't get back to working on it again tonight.
That kit I got drills into the bolt/screw and then has some angled threads to bite into the drilled hole to hopefully get it out.
Old 01-16-2007, 11:29 AM
KuHL 951
Hey Man
KuHL 951's Avatar
Ditto on the Craftsman set, they saved me many times over the last 3 years.
Old 01-16-2007, 01:54 PM
MyBlackCar
MyBlackCar's Avatar
Or use left handed drill bits.
Old 01-16-2007, 04:46 PM
billthe3
billthe3's Avatar
I've been trying forever to find a set of these but no one has any. Its really pissed me off - we had a set in autoshop in highschool and they were the greatest things ever. This thing I got looks like it may do close to the same thing.
As for the other socket ones, do those work on round bolts?
Old 01-16-2007, 05:01 PM
robert944h
robert944h's Avatar
Snap-on has left handed drill bits
Old 01-16-2007, 05:13 PM
KuHL 951
Hey Man
KuHL 951's Avatar
Originally Posted by billthe3
...As for the other socket ones, do those work on round bolts?
Yes they do especially if you tap them a bit with a socket extension first. I've actually had trouble getting the cap screw out of the socket it bit down so well. I avoid drilling in confined spaces if I have a choice. If you break off an easy-out type tool you will never be able to drill it and end up using the bolt remover socket anyway. Intake manifolds are not torqued that much anyway so the socket type removal tool should work fine.
Quick Reply: headgasket on hold: stripped 5mm hex bolt, how to get out?
