Thoughts on Risoline
The 928 guys (used to?) use it to unstick lifters. I have not heard of it being used in a while. I would be inclined to try it if I got a stuck lifter, but only after an oil change with good 0w-40 oil and some careful driving, and then I would change the oil after the lifter unstuck to get the Riselone out. Not sure what else I might want to use it for. I do not think it would damage seals but I could see it removing gunk is protecting a bad seal.
If an engine is generally gunked up, several of my friends recommend Auto-RX. One has a high mileage supercharged Miata and has driven the car hard for at least a year since the Auto RX and it has not blown up. I have not tried it myself.
http://www.auto-rx.com/index.html
-Joel.
-Joel.
I've used Risoline myself a time or two
Destroys seals? Never heard that before. It isn't in the system long enough, as far as I know.
Kerosene, automatic transmission fluid, can, and will work as well most the time, IF used as prescribed,directed on the Risoline can instructions. In other words............don't drive the car with it in there, only used at idle, in the garage (within reason). I believe the Risoline is pretty much kerosene............anyway. Just note, there IS no such thing as "fix in a can". Your seals are gonna leak only because they are SHOT. Good luck!! just my .002.
